What is this thingamajig ??
Old 12-22-2003, 09:39 PM
Nickiboy's Avatar
Nickiboy
Nickiboy is offline
Im trying to identify a part hanging under my dash board just to the right of the steering wheel. its an electronic black box with 7 connector prongs about 2 inches by 2 inches by 1 inch. Nothing is hooked up to it and im wondering just what the hell is it for. The part # on it is F2TB-10D840-AA with ford emblem on it........... anyone got any ideas ??
Old 12-22-2003, 09:45 PM
f350xlt460's Avatar
f350xlt460
f350xlt460 is offline
possiably an AIC plug? (aux idle control)
Old 12-22-2003, 11:27 PM
BigBully's Avatar
BigBully
BigBully is offline
I guess we need a picture, It dont sound like an AIC by the size. An AIC will have a small screen and buttons on it.
Old 12-23-2003, 03:44 AM
RubberDuck's Avatar
RubberDuck
RubberDuck is offline
Not sure without a pic, but if its the one right above the transmission housing its a trailer brake controller plug. You can buy the plug that goes into it and wires to the brake controller at your local ford house. Hope that helps.
RubberDuck
Old 12-23-2003, 07:04 AM
f350xlt460's Avatar
f350xlt460
a brake controler plug would have 6 wires i think, also, if my first post was a little confusing, i ment to say an AIC plug, not the whole unit.
Old 12-23-2003, 11:25 AM
BigBully's Avatar
BigBully
BigBully is offline
You did say AIC plug, But I said I dont think its an AIC because of the size he Described. And I dont think the AIC plug has A Ford Emblem on it. The Emblem is whats confuseing me.
Old 12-23-2003, 11:29 AM
bcmmdl's Avatar
bcmmdl
bcmmdl is offline
Do you not electronic 4x4 switch. I could be a part for that if your shift is on the floor.
Old 12-23-2003, 12:27 PM
96P_Stroke4x4's Avatar
96P_Stroke4x4
96P_Stroke4x4 is offline
Smokin'
are you referring to the annoying door chime box? i'd have to go out and take a look. do you get a chime with the key in and door open?
Old 12-23-2003, 01:16 PM
SMB's Avatar
SMB
SMB is offline
Is it the OBDII port? Same place you'd plug in if you had a microtuner?
-Shawn
Old 12-23-2003, 04:23 PM
cookie88's Avatar
cookie88
cookie88 is offline
I'm not sure if his 95 has OBD II or not, but I think you are correct that it is the diagnostic port.
Old 12-23-2003, 11:30 PM
Nickiboy's Avatar
Nickiboy
Nickiboy is offline
I do have a 1705 microtuner, and its not the port for it......... im going to photograph it and upload it for better identification.
Old 12-23-2003, 11:32 PM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
jrs_big_ford_f150 is offline
If its a 95 and uses the old EEC-IV computer, the diagnostic port will be in the engine compartment.
Old 03-20-2005, 02:08 AM
rangerang's Avatar
rangerang
rangerang is offline
It's 99% the door open & key in, lights on, ignition on alarm.
My '90 Ranger has the same part but numbered E9EB-10D840-AA and
that's what it is. I pulled mine because it's been getting less and less
audible. I disassembled it and found that, rather than using a <$0.25
speaker, Ford invented their own by mounting a coil on the PC board and
inserting a huge E-bar through it that affects (magnetically vibrates) a
ferrous disk that is mounted in plastic just below the E-coil. Unfortunately,
the distance between the disk & coil is critical and also, unfortunately, is
determined by a foam ring that, in my case, tends to disintegrate. If this
sounds too complicated; yes, Ford, it is. Geez guys, just buy a speaker.
I've found that a 32-ohm speaker across the coil works, as well as a few piezo elements I had on hand sound ok when wired across the coil. I'm not
sure if the coil impedance is or isn't required for the chime oscillator so I'm
leaving it in place, even though it will be useless without the disk. Speakers
that I have of 16 & 8 ohms tend to be too loud.
Unfortunately (but not very), these all require cutting the case to mount
the sounding device. I'll still make the rounds to see if I can find a very
thin O-ring that might be used to remount the disk, replacing the rotting
foam, since the truck is currently up on stands for a fuel tank drop and I
have the time.
Anyway, my searches for a replacement have shown me that the important
reference is anything-10D840-anything. Obviously, the first "anything" will
indicate the first year of manufacture and, apparently, the middle number
indicates the function- in this case the alarm chime. I don't know if the
year affects the design, although I expect it would.
If yours has nothing connected to it, I would suspect that it has been
disconnected by a (maybe) previous owner who was irritated once too
often. There should be a matching connector in the very near vicinity if
you care to reconnect it. Personally, I love this alarm and want mine back.
Old 02-04-2006, 02:50 PM
clchambers's Avatar
clchambers
clchambers is offline
Rangerang is absolutely correct. It's the door open & key in, lights on, ignition on alarm. I found it ridiculously simple to disassemble the box (mine was hinged and easy to open) and replace the deteriorated foam on the ferrous disk. I used a piece of foam from a reusable filter from a window A/C unit. For a template I used the original ferrous disk and cut around it then cut out the middle. No need for adhesive when reassembling. Doing this would eliminate the possibility of causing undesirable volume/tone and it's cheap and easy without the need for any modifications to the chime box.
Old 02-04-2006, 03:27 PM
cookie88's Avatar
cookie88
cookie88 is offline
Welcome to Ford Truck Enthusiasts clchambers.
Quick Reply: What is this thingamajig ??
