Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 12-21-2003, 11:10 PM
MJEmerson MJEmerson is offline
MJEmerson is starting off with a positive reputation.
Low oil pressure at Idle
I have a 1997 F150 4x2 LWB 4.2L V6 (149,000 miles) I am preventitive maintenance junkie and pamper this thing. The other day on a long trip (300+ miles) I started haveing the problem of the oil pressure guage bouncing then bottoming out. The oil pressure light would come on, and then when I would give it gas or put it in Park the oil pressure would return to normal. As the trip went on I developed a knock and a rattle that sounds similar to a heat shield when I get on the gas at about 55mph or on hills. I am going to try running heavier oil and see if this helps. The only thing i could think of is the oil pump or the spring in it is bad. Any advice.
Truck is clean, Oil was just changed, no other work done at all other than prev. maintenance, and a K and N air filter. Also am having the problem of headlight dimmer, heater/ac temperate switch wearing out. I already had to replace the signal arm/wiper/high beam on the steering column (65 dollar cheap fix). Other than that its been a perfect truck and If this oil pressure deal is a do it yourself project under 200 bucks Ill stay a happy soldier.
__________________
ARMY INFANTRY LEADS THE WAY
  #2 (permalink)
Old 12-22-2003, 10:21 PM
well the oil change did the trick....I think I had a bad oil filter that caused the problem.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
