problems keeping truck running without foot on gas
my 97' explorer sport recently had the idler, tensioner and belt replaced. when we got the truck back the thermastat was not working either. we replaced the thermastat the other day and it was running great... except for the belt was still screaching at start up ever since we had the other work done. however, later yesterday we had problems starting or should i say keeping the truck going... it starts but, unless we keep our foot on the gas it dies right out. we thought maybe it could be water in the gasline. so we added gasline antifreeze and tried to run it. even after an hour driving it is still stalling out unless we keep our foot on the gas. so, the other thing we thought was maybe the fuel filter... any ideas? please someone help!
So, you think it s either the idle air control (IAC) valve or simply a blown off vacuum hose. I know you said that it's a cylindrical with a plug on it and it's mounted on top where the throttle plate is with 2 bolts. Do you have any more details about the location? Not quite sure where that is? Do you think it could be a manifold o-ring leak? My engine is a SOHC engine, but I don't recall getting a notification for this problem.
Vacuum lines are important here as well--there is a vacuum tree on the upper intake near the firewall; make sure that all of those ports have something going to them. Follow each one of those lines to make sure that they go somewhere; if one of those is disconnected, you'll see the same symptoms.
stavovy
04-25-2012 06:30 PM
r10kidds
30
09-04-2010 11:00 AM
Smokey Mountain Iggy
08-21-2003 06:46 AM
FrontYardMech
04-19-2002 05:08 PM
