Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > 4 Cylinder Engines
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 12-21-2003, 04:39 PM
ltabora ltabora is offline
ltabora is starting off with a positive reputation.
Question Intake Air Sensor
I recently ordered a Intake Sensor Mod, but I'm not quite sure where the intake air temperature sensor is in a 1996 Ford Ranger 2.3L. Can anybody help?
  #2 (permalink)
Old 12-21-2003, 08:07 PM
Dealford's Avatar
Dealford Dealford is offline
Dealford is gaining momentum as a positive member of FTE.
Welcome to FTE ltabora.
The IAT sensor on the 2.3 is on the air duct that attaches to the throttle body. The sensor is about 6" away from the throttle body on the side of the air duct.
__________________
97 Ranger (metric half ton) 2.3,5spd. Saphire blue metalic w/matching cap & Stock Rims 4 winter.
92 Town Car....Sweet PITA.
90 BII 4x4 Ongoing Project, aka PITA
63 Fairlane, Gone to my buddy Chuck.
It Aint Fun Unless It's Done The Hard Way!
  #3 (permalink)
Old 12-22-2003, 10:22 AM
Thank you very much. Managed to locate the IAT Sensor with your help.
Regards,
LT
  #4 (permalink)
Old 03-18-2004, 08:44 PM
Vin 95 Vin 95 is offline
Vin 95 is starting off with a positive reputation.
I got one of those sensor mods and it made my 95 run like crap,so after some checking i found that since its only a resistor,Imeasured it and it was Too low of a resistor.acording to the book, you want a higher resistance value to make your computor think its colder out than it really is,thus it advances the timing through the CPU.Iwent to radio-shack and got one,69K ohms.it worked alot better.
  #5 (permalink)
Old 05-07-2004, 03:04 PM
billtcat billtcat is offline
billtcat is starting off with a positive reputation.
Hey Vin 95
How do you install that resistor? Would it help my 97 Ranger 2.3?
Bill
  #6 (permalink)
Old 05-21-2004, 02:14 PM
You just unplug the sensor and fold the resistor wires over about half way and plug it into the wire plug that you unpluged from the sensor,it does'nt matter which way you plug it in.The inprovement is only slightly noticable.Like going up hill,say your truck downshifted at halfway up the hill,with the resistor it may go another 50-75 yards before downshifting.
  #7 (permalink)
Old 05-21-2004, 07:34 PM
I have a 5 speed
Ay advantage to using the resistor?
  #8 (permalink)
Old 05-22-2004, 11:14 AM
Slight power increase(10 HP)But you seem to get a smoother idle,Because the resistor tells the PCM that its alot colder out than it really is,so the PCM advances the timing a degree or two.
  #9 (permalink)
Old 05-22-2004, 11:47 AM
By the way,check the resistor with a multi-meter.you want AT LEAST 69,000ohms,any less will not give a performance increase.The book says-the IAT is a thermal resistor that changes value at different temps.For example,at 68 degrees F the resistance is 27,000 ohms , at 160 degrees F it is 7,000 ohms.You might even experiment with higher resistance for better results. I went with 69,000 because I just wanted to compensate for running the A/C. P.S. resistors come in odd sizes,33,47, 56 etc. But they are only $2. at radio shack.
  #10 (permalink)
Old 08-23-2004, 05:58 PM
russis russis is offline
russis is starting off with a positive reputation.
Smile IAT sensor
Instead of working to get the perfect resistance for your IAT (intake air temperature) sensor in different conditions you could try a variable one. I think these guys have something like a POT to adjust your IAT.
http://hurricane-horsepower.com
You could probably build one for less than they charge if you are handy with electronics.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
