Can someone identify this engine?
I wasn't sure where to post this so if it needs to be moved, then please move it.
It's an old V8 with the pistons, rods, and main caps.
Pistons measure 4 1/2" diamater. The pistons were stuck in the cyliders but it looked like the cylinders were roughly 6 1/2" deep.
Intake manifold is 4 barrel and on the top it has the letters HW and 2208000
On the side of the block it has 2468030-3 and below that it has D N RL
It has 2 bolt mains and the block is roughly 14 1/2" and 14" tall.
Also, there are only three exhaust ports on each side and I could not find any holes for the manifolds or headers to screw into. Strange.
I know a lot of it is probably useless info. but that's all I got.
Help us out a bit. Is this definitely a Ford or is it brand unknown? Overhead valve or flathead? Approximate stroke? Front or rear distributor? 5 mains or 3?
4.5" bore is HUGE. The 460 is only 4.36" bore. That thing is most likely a truck engine, which adds another question: gas or Diesel?
The brand is unknown.
I'm thinking OHV. That didn't even cross my mind when I was checking it out.
Approximate stroke?
I'm not sure, I'd need to try to get the pistons loose first. 4"?
I'm pretty sure it's a front distributor. 5 mains. I do know there were more than three.
gas or Diesel?
I'm not sure, I thought I saw sleeves in the cylinders. Diesels have sleeves right?
Thank you for the help!
Approximate stroke?
gas or Diesel?
CharlieLed
09-09-2023 06:04 PM
rsh1966
07-27-2016 09:08 AM
79BroncoJD
07-06-2002 04:19 PM
