Best way to clean MAF...96 ranger 3.0 - Ford Truck Enthusiasts Forums
Old 12-20-2003, 11:26 PM
sd1 sd1 is offline
sd1 is starting off with a positive reputation.
Greets All -
Was wondering what would be the best off the shelf product I could use to clean my MAF with please? Any help appreciated..thank you
Old 12-22-2003, 11:15 PM
fordeverpower's Avatar
fordeverpower fordeverpower is offline
fordeverpower is starting off with a positive reputation.
you might not supposed to clean that kinda like the throttle body isn't supposed to be cleaned.
Old 12-22-2003, 11:51 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
Pro-M says to use a pipe cleaner very gently so you don't break the element. Other than that, carb/choke/throttle body cleaner should work.
Old 12-23-2003, 04:48 AM
sd1 sd1 is offline
Thx EPN I went the O2 safe throttle body cleaner after I removed it from the throttle body......
Cleaning the MAF? Trevor.801 Excursion - King of SUVs 4 02-19-2015 11:02 AM
MAF sensor Gary E K 1999 to 2016 Super Duty 1 08-24-2012 10:36 PM
MAF cleaning question aphotic26 1999 to 2016 Super Duty 12 09-02-2010 08:53 PM
Cleaning the MAF skinsey Modular V8 (4.6L, 5.4L) 6 10-13-2009 07:36 PM
cleaning the maf ericnj75 1997-2006 Expedition & Navigator 2 08-25-2007 03:50 AM
Tags
2001, 2004, 30, 4x4, 96, body, car, clean, f150, ford, guide, maf, ranger, throttle, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
