Thrust Bearing Replacement - Ford Truck Enthusiasts Forums
Old 12-20-2003, 02:33 PM
SDDADD SDDADD is offline
SDDADD is starting off with a positive reputation.
I BOUGHT A 2000 E 150 TWO MONTHS AGO WITH 59,000 MILES.
WARRANTY WAS UP TUESDAY... THE ENGINE STARTED MAKING NOISE THURSDAY AM. I FOUND OUT I HAVE A BAD THRUST BEARING. I HAVEN'T BEEN BACK TO THE DEALER YET BUT WANT TO KNOW ALL I CAN BEFORE I GO IF THIS IS A FORD CONCERN. WHAT CAUSED IT AND CAN IT BE FIXED WITHOUT A NEW CAMSHAFT OR ENGINE.
ANY HELP OUT THERE?
Old 12-23-2003, 05:19 PM
MJEmerson MJEmerson is offline
MJEmerson is starting off with a positive reputation.
thrust bearing keeps the cam shaft in place and from moving front to back. the bearing itself can be replaced often without having the even take the cam out. Should not have to replace the cam unless the problem was let go long enough to damage it. but fix it asap.
Old 12-24-2003, 07:24 AM
Well, I hope you are right.... I probably drove it a couple hundred miles after I started hearing the noises of the bolts hitting the rear of the engine.... I hope to get it fixed after the new year. It is parked for now. Thank you for your reply.
Old 12-20-2004, 07:04 PM
flyhound flyhound is offline
flyhound is starting off with a positive reputation.
Cam shaft or Crankshaft? Don't you mean crank?
Old 12-25-2004, 09:46 PM
travlnman travlnman is offline
travlnman is starting off with a positive reputation.
I'm no mechanic, but I'm not aware of the crank having a thrust bearing. It is held in place by the main bearing caps and the bearings themselves. The cam on most Ford's have a small bearing or "thrust plate" that keeps the cam from walking back and forth in the block, as the cam bearings are not held down by bolts or caps. The only exception would be in an overhead cam engine, or maybe I'm just crazy.
Dreaded 2.0 Zetec Crank Walk - How to set Thrust in vehicle? piscespokerbrat Escape & Escape Hybrid 2 06-28-2015 07:37 AM
sealed power main bearing grooves rayinsd 1997 - 2003 F150 8 06-12-2012 06:21 PM
#3 Thrust bearing Replacement jesse_h97 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 0 03-30-2010 08:25 AM
v10 crankshaft thrust washer Tony G Modular V10 (6.8l) 7 07-30-2008 10:31 PM
Thrust Plate out of production jwtimme 1967 - 1972 F-100 & Larger F-Series Trucks 3 10-30-2001 10:19 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
42l, 46l, backv8, bearing, bearings, camshaft, crank, ford, front, moving, noise, replaced, replacement, thrust, windsor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
