Wheel Backspace Question for StrangeRanger
StrangeRanger (and others...),
I saw a post from several months back where you describe the details of the wheels on your '96 F150.
It sounds like you are running 16x8 wheels with about 4 7/16" backspacing.
Do you see any clearance issue with the tires hitting the Radius arm at full wheel lock?
If you went to a larger tire (33x12.5), do you think that the tire would hit the radius arm?
Here's why I ask.
I am planning to put 33x12.5's on my '95 Bronco using a 10" wide wheel. My 31x10.5's on the stock 15x7.5 wheels don't rub now, in fact I have well over an inch of clearance at full lock. I measure the backspace on my stock wheels to be 3.75".
My real question is: Will I be OK with a 4.5" backspace like you say you are running now (which I would get with a 16" wheel), or do I need to stick with a ~3.5" backspace typical of 15" aftermarket wheels?
Can you please confirm your previous observations/estimates and tell me what you think?
Thanks!
MerCrew66
Here's why I ask.
Thanks!
MerCrew66
I am running the AR Baja 16 x 8 zero offset wheels, which measure 4-7/16" backspace, and 30" tires. There have been absolutely no clearance problems whatsoever. The truck is in storage for the winter so I cannot measure the clearance from my tires to the radius arm at full lock, but I strongly suspect that a 32" tire would either clear completely or only touch lightly and only at full lock.
92-150man
12-12-2010 09:27 PM
MerCrew66
06-08-2003 11:54 PM
