Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-20-2003, 07:31 AM
Night_Mayor Night_Mayor is offline
Garage is empty, add now
Night_Mayor is starting off with a positive reputation.
SOHC V6 Oil Pump Change
Can I do this without removing the engine?
BTW Its insane to design something like this(have no Oil pan and putting the crank case inforcement thing over the *#%^@*$ Oil pump).
  #2 (permalink)
Old 12-30-2003, 06:09 PM
hreed hreed is offline
hreed is starting off with a positive reputation.
I tried it on my 2.8. The manual says it can be done by jacking the engine up at the mounts with a 2x4. Don't believe them. If you are persistent you can get the pump off, but will not get it back on. Plus, the oil pan gasket is nearly impossible to get back on that way. I know it sounds like a lot of work, but pulling the engine is a better option.
  #3 (permalink)
Old 02-10-2004, 10:22 AM
GizmosStang GizmosStang is offline
GizmosStang is starting off with a positive reputation.
WHEN THE MANUAL SAYS THIS IS A VERY DIFFICULT TASK REQUIRING SEVERAL SPECIAL TOOLS AND REMOVAL OF THE ENGINE FROM THE VEHICLE...
You should back away close hood and scrap it...
Nothing on the 4.0L SOHC can be accomplished in the truck if you have to remove that sorry excuse for a oil holder on the bottom end you will have the engine out it will leak oil for the rest of its life...
Its far easier to pull it do what you need to do and put it back in than attempt anything in the tight quarters under it.
Tags
40, change, changing, f150, ford, modify, oil, pan, pump, ranger, remove, replacement, sohc, v6, washer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
