fast 351w bronco
fast 351w bronco
hi im a proud owner of a 88 351w bronco. im planing on rebuilding the engine and makeing it have more hp. what would be some ways i could realy make this truck haul aszzz? money is not a problem. maybe puting in a super charger, cams, performance heads ect... i already put in a custom dual no cats, glasspacks exsaust. any ideas? thanks
Well if money isn't a problem, determine if you wanna say I have stroker motor, a blown motor, or a nos motor, or all of the above. Go down to a local speed/ machine shop and throw money at them, you will go fast. A set of afr heads, a stroker crank, and a decent cam, with the appropriate fuel delievery and chip should net you huge hp and tq. Too many ways to go about makeing hp and tq, all have their advantages and disadvantages, which one would you like to do? Don't forget about the tranny and rearend. later
Well short of having the rotating assembly balanced. You have the 351 rods, free. 302 stock type pistons, the price varies $150-400+. The stroker crank runs $280-350. Pretty cheap huh? YOu take all the parts above, your flywheel/flexplate and damper to a machinist and have them balanced. The stoker forces the motor to take in more air, when you stroke a motor you increase the crank size/ stroke, the piston travels further down drawing in more air, you feed it fuel and there is where the power is increased, usually the stroker will supply more tq than hp but if you add a good set of heads and the right cam, along with the right amount of fuel you could potentially have 400-500 reliable hp and even more torque, if the combo is proven or well thought out. The stroker addition alone on your stock motor should give you 20-25 more tq and maybe equal if not less hp, if I had to guess. Call a machinist in your area and see what they charge to balance a rotating assembly, the price will vary due to differences in crank quality, but they should be able to give you a rough estimate of what to expect, should it cost more than suggested don't be suprised. later
stroker yes \m/
the stroker engine sounds like a good idea 400-500 hp would make her quick hu. with some good heads and a good cam would probaly do the trick. would edlebrock probaly be the best way to go on the heads and cams? for the most hp? ive heard of guys putting in gt40 heads in there trucks. thanks for all the great ideas jwtalor probaly if i put this engine in ill have to put in a high hp tranny hu? driveline. thanks guys
blackhawk21
04-02-2017 07:28 PM
bradleyj
13
04-09-2003 06:47 AM
