5.4L Will not idle
5.4L Will not idle
1999 Expedition will not run after it starts unless I use the accelerator to keep the RPM above 600. In other words it will not idle by it-self. Also the service engine light soon, has come on and does not go out.
Is there a sensor that needs to be changed or could it be a fuel filter? I thought maybe the injectors were dirty and ran a bottle of cleaner thru them, but no help.
I agree-- sounds like the IAC (idle air control), a valve located on the intake plenum tha t can be changed easily. I recommend that you have someone scan the computer to check for other possiables such as the ECT (coolant temp) sensor since you stated that the ses light was on. Most likely (95%) it is the IAC.
crescentwrencher
04-04-2008 08:37 PM
