'04 F150 specs? rotors, axle
Will do my best!
95CobraR,
Let me look up the rear axle data for you and add it to the webpage I made. The data is not all in one big page that I can paste the whole thing in.
Here's what I found:
SRAces
USAF (ret)
2004 F-150 Rear Axles Specs
SRAces
USAF (ret)
With the optional Payload Package you get bigger everything. Springs, shocks, tires, heavyduty frame, Upgraded Auxiliary Trans cooler, heavy duty wheels. Upgraded Radiator and Big 10.25 4.10 Rearend. I just ordered a standard cab 2wd set up like this. My First Brand New Truck Is A Ford? O-Well change can be good.
1956Mark11--I saw the 13" in the front/ 2" thick. The rears are larger? thickness? Is that standard or do they change with the Heavy Duty payload package?
The more I look at the specs for the '04 F-150 HD; the more I am impressed with it!
Thanks 95CobraR. I think i reserched this upgrade to death.
I was pretty sure what I wanted based on what I have now which is an old 86 3/4 ton chev. 350 motor buildt 400 trans and '79 limited slip rearend with air lift bags. I figure this new Ford has to do the same or better job and use 40% less gas.
Old chev's are not known for milage and when you add 4 barrels and cams and such well it don't get better. But I can PULL!!!
boblaw132
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
10-31-2002 08:18 PM
