1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Sea Foam????
Old 11-20-2002, 09:34 AM
Waxy's Avatar
Waxy
Waxy is offline
Sea Foam????
Old 11-22-2002, 02:26 PM
FlyinFord's Avatar
FlyinFord
FlyinFord is offline
Sea Foam????
One of my freinds keeps using this product called Sea Foam on his Toyota. It is an engine cleaner that gets "sucked up" through the vaccum line going to the brake assist. The engine sucks it up, quits, wait 10 min, fire it up, and then drive down the street and smoke out your neiborhood.Has anyone here heard of or used this product. Is it good or bad. My buddy says that his truck always runs better when he is done with it.
Thanks for any input
Morgan
Old 11-22-2002, 03:56 PM
FortyFords's Avatar
FortyFords
FortyFords is offline
Sea Foam????
I believe its a decarbonizer.I think its used on engines that do alot of idling,maybe diesels.I have no expeirence with it.
I would be careful doing something like that,for fear of a peice of carbon breaking loose and causing harm and on an older engine with lots of miles.May cause a loss in compression(psi)though not totally but slight drop.
Just my $.02
Rich
02 F250 4x4 SC 5.4v8 6spd 3.73ls Trueblue/Silver and Chrome Nerfs
"All Levers"
Old 11-22-2002, 04:10 PM
Big Red F250 SD's Avatar
Big Red F250 SD
Big Red F250 SD is offline
Sea Foam????
Sea Foam is used on outboards (boat motors) to remove carbon build up. It does create a lot of smoke. I've never heard if it used on a truck/car engine.
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: Sea Foam????
