F250 gas mileage
#30
2008 Ford F-250 4WD with a 5.4L
I would like to know who is getting 20MPG with a F-250 4WD 5.4L
You may want to invest in a new calculator.
I average about 13.5 Hw/City combined and on a long highway trip I might get 14.5 around town you can expect to get around 12.5
The 5.4L on thit truck is a big mistake if you intend to trailer over 6000 lbs. It is grossly underpowered since the truck already has a 6200 GVWR.
Another Ford engineering blunder that you don't find out about until you are tugging a load. They rate the truck for over 10,000 lbs and I can tell you first hand after towing an 8000lb boat around that you will be sorry you settled for the 5.4L. I listened to story after story of guys towing big box trailers with double super duper triple guns with compressors and tool boxes on board but after you add up all the weight I am willing to bet that it will amount to around 5000 lbs which the truck can handle with ease.
But then WTH would by buy an F-250 for if you were not intending to carry some real weight?
If you intend to trailer over 6000 lbs serously suggest you go for the Diesel since it has twice as much torque.
You will be much much happier in the end.
Starwarrior
Starwarrior
hpcbmw
08-29-2015 07:49 AM
01F2504x4sls
Modular V8 (4.6L, 5.4L)
08-26-2011 02:37 AM
