Broke my transmission again...
Damned C6 trannies! I think I broke this one (I broke my first taking off hard from a stop sign ) with my "wuss" I-6 again. I grabbed this tranny and rebuilt it and stuffed it into the truck. Hopefully it's just something awry in the valve body. I was going down the road last night and it started shifting funny, go up to 4500rpm in 1st and slam into 2nd and 3rd real quick. I put it in park and got out and checked the fluid (which was fine) and went home, and it shifted fine. This morning, I left for school and it was shifting fine for about 3 miles, then it started acting up again. Hopeing I could get to school for that damned exam, I went on and made it to about 200 yards from the school where it went into a neutral like state. All I got was nothing but a revving engine. I tried reverse and it was fine so I backed into the school. I got towed home and it's still doing about hte same thing, reverse is fine but no forward motion. When I shift through the gears from neutral, I'll get a jerking when I put it in 1. Any suggestions? I'll be tearing into it in about an hour.
Same problem i had bout a month ago, had reverse, but no drive gears. So tore it down to find out, the flex plate inside planetary carrier had shattered into three pieces, i just went ahead and rebuilt it, now i got another problem, every gear is in reverse neutral and park! Did you try replacing the mod valve or try adjusting the bands!
So far...I'm in the process of dissasembling the valve body. I think I found the problem as the forward clutch assembly engages properly when using air. I'm 80% sure that the problem was caused by a stuck valve. I can't get it out of the valve body for anything. I've tried tapping it gently(no spare valvebody to play with) and using a magnet to get it out to no avail.
marcomjl
01-24-2011 08:49 PM
Old93f150
09-17-2010 08:43 PM
bobj49f2
25
05-11-2010 02:19 AM
