Door ajar Light stays on - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-15-2003, 03:29 PM
Kingdom1 Kingdom1 is offline
Kingdom1 is starting off with a positive reputation.
The following items are not working on my 2002 Ford F250 4x4 Crew Cab. The door ajar light stays on all the time. The interior lights stay on all the time. The automatic door locks no longer activate when you start driving as they used too. The power windows and radio do not remain powered for the five mintue delay after the ignition is turned off as they previously did. I do not have an alarm on this truck. I have hooked a superchip diagnostic programmer up and I get the error #603 internal control module KAM error) I have found a website that explains this code( faulty PCM InOpen PCM pin, disconnect B+,ternal control module KAM error) (Huh?) How can I fix this problem. I have tried spraying DW40 in the latches as some suggets and it hasn't worked.
Old 12-15-2003, 09:28 PM
99f350sd 99f350sd is offline
99f350sd has a good reputation on FTE.99f350sd has a good reputation on FTE.
The gem module powers all the stuff you are talking about.....I don't think the PCM has anything to do with it....I could be wrong!
Old 12-15-2003, 09:38 PM
Thanks for the info! Now, could you tell me where the GEM module is located?
Old 12-15-2003, 09:53 PM
Fordman4x4's Avatar
Fordman4x4 Fordman4x4 is offline
Fordman4x4 is starting off with a positive reputation.
Sounds like the GEM module never sees the door close, especially cuz you say the door ajar light and the interior light's never go out. You should check out the door switch in each door...
wait...when you get in and just put the key in the ignition (do not turn key) does the buzzer start going off. If so then it would be a problem with the driver's side door switch. I just remembered when i work under the dash of my truck i can't stand listening to the radio because the buzzer keeps goin off with the door open. If no buzzer then it would be the pass. side door switch...
good luck
Nelson
Old 12-15-2003, 11:10 PM
Even if the drivers door sw is open all the time the gem controlled light will go out eventually. Check the dash dimmer sw?
Old 12-15-2003, 11:17 PM
Fordman4x4's Avatar
right but wouldn't it recycle every drive cycle?
Old 12-16-2003, 08:27 AM
Even with the key off the light should go out after awhile. With all the other probs he has it sounds like a major malfunction. Yes I would check the door sw's.
Old 12-16-2003, 11:46 AM
The problem has evolved further by itself; now the dome lights stay on for about 45 seconds after you start driving the truck and then go off. After I park the truck they all stay on for about 10 minutes,.. go figure.. The auto delay door locks, delay radio and window funtion after the ignition is off still do not work at all. The door ajar light also stays on all the time. The truck was in a roll over acident and the cab was partially replaced and 3 of 4 doors were replaced with used doors. I have had all the doors apart and there is no door switch that I can find anywhere in any of the doors? The two front doors were origonally taken from an Excursion but that should'nt make any difference from what I've been told. Can anyone tell me where the GEM Modlue is located?
Old 12-16-2003, 01:57 PM
The gem is behind the fuse box and the switches are inside the door next to the latch mechanism or below it. Pull the connector that should simulate door closed.
Old 12-16-2003, 02:04 PM
Where will I find the connector? By the switch inside the door?
Old 12-16-2003, 06:08 PM
Its attached to the latch on the bottom. If you stick your hand in there you'll feel the wire...its on the sw.
Old 12-16-2003, 11:07 PM
FortyFords's Avatar
FortyFords FortyFords is offline
FortyFords is gaining momentum as a positive member of FTE.
after chking on what has been suggested .
Because this truck was a rollover I would ck where the wires enter the doors and where the enter the door pillars this is a common place that gets pinched or crushed when bodyshops do there pulling and welding .
Rich
Old 12-17-2003, 10:55 AM
Thanks for all the advice! Today, I plan to remove the panels on the doors to check each switch. Can anyone tell me a way to test them in place? As I understand it, there is only one wire at the switch? I would think it would require two wires to complete a circut?
Old 12-17-2003, 03:01 PM
The plot thickens; I discovered that the right front passenger door switch acts in reverse of what it should. When the door is opened, everything works properly. The door ajar light goes out and all the other delay functions work properly. When the door is closed, major malfunction! I tried an easy fix of crossing the two wires in the harness that go to the door switch but it didn't change a thing. Any ideas as to why or how the switch could work the opposite of the way it should?
Old 12-17-2003, 03:06 PM
black98f150 black98f150 is offline
black98f150 is starting off with a positive reputation.
my dome light and the door ajar light was staying on for a while also.......how i fixed it was sprayed some silicone spray in the door jams,hinges,everything that keeps the door closed and makes it open..........problem solved!!!!!!!!!
98 ford expediton ajar and interior lights stay on Ford-Muscle 1997-2006 Expedition & Navigator 13 02-13-2016 07:09 PM
No cruise, door ajar light, no power point power johnwm 1999 - 2003 7.3L Power Stroke Diesel 3 01-17-2016 10:09 PM
DOOR AJAR LIGHT ON ALL THE TIME lhud 1999 - 2003 7.3L Power Stroke Diesel 11 11-14-2015 09:20 PM
Electrical Problems HELP! getsmart_86 6.0L Power Stroke Diesel 10 10-20-2015 08:27 PM
KAM POWER dannyboy950 6.0L Power Stroke Diesel 47 07-06-2015 10:14 AM
Tags
1999, 2002, 2003, 99, ajar, cab, door, escape, f250, ford, light, module, ranger, stays, supercrew
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
