2002 Explorer fuel filter change
Old 12-14-2003, 03:58 PM
volks's Avatar
volks
volks is offline
Question 2002 Explorer fuel filter change
Can I use the scissors type release tool for the fuel line fittings on this filter ?? It has two lines in and one line out ?
Thanks !
Old 12-15-2003, 01:35 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
It should work.
Old 12-17-2003, 11:45 AM
edward r's Avatar
edward r
edward r is offline
I have the same vehicle. Where is the filter located and how hard is to replace??
Old 12-19-2003, 05:34 AM
volks's Avatar
volks
volks is offline
fuel filter is located under the pass front area , there is a heat sheild in front of it , has 3 {13 mm} head bolts holding it on , then a small plastic splash pan behind it , 2{10 mm} nuts hold it on. The fuel filter has 2 small lines on the inlet side , this takes a special release tool available from napa , {don't have the p/n handy} but it lists in the book for the 4.0 explorer , and the scissors type release tool for the outlet side. I do have the Napa p/n for the filter , it is 3424 . {2 inlet,1 outlet} , but they also listed a diff p/n which is 1 in/1 out. ck to see which one you need before hand{ I didn't , made an extra trip } Hope this helps !!
ps: you will need to have the x up on jack stands to have room to work
Old 12-19-2003, 06:08 AM
edward r's Avatar
edward r
edward r is offline
many thanks
dobenator
08-03-2015 01:58 PM
Ibuildmyown
06-01-2015 11:07 AM
dstraw
12-01-2014 07:53 AM
86pullerf350
09-30-2014 03:53 AM
rockittsled
02-20-2014 09:13 PM
Quick Reply: 2002 Explorer fuel filter change
