2002 Explorer fuel filter change - Ford Truck Enthusiasts Forums
Old 12-14-2003, 03:58 PM
volks volks is offline
volks is starting off with a positive reputation.
Question 2002 Explorer fuel filter change
Can I use the scissors type release tool for the fuel line fittings on this filter ?? It has two lines in and one line out ?
Thanks !
Old 12-15-2003, 01:35 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
It should work.
Old 12-17-2003, 11:45 AM
edward r edward r is offline
edward r is starting off with a positive reputation.
I have the same vehicle. Where is the filter located and how hard is to replace??
Old 12-19-2003, 05:34 AM
fuel filter is located under the pass front area , there is a heat sheild in front of it , has 3 {13 mm} head bolts holding it on , then a small plastic splash pan behind it , 2{10 mm} nuts hold it on. The fuel filter has 2 small lines on the inlet side , this takes a special release tool available from napa , {don't have the p/n handy} but it lists in the book for the 4.0 explorer , and the scissors type release tool for the outlet side. I do have the Napa p/n for the filter , it is 3424 . {2 inlet,1 outlet} , but they also listed a diff p/n which is 1 in/1 out. ck to see which one you need before hand{ I didn't , made an extra trip } Hope this helps !!
ps: you will need to have the x up on jack stands to have room to work
Old 12-19-2003, 06:08 AM
many thanks
Fuel question dobenator 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 08-03-2015 01:58 PM
Fuel line question Ibuildmyown Explorer, Sport Trac, Mountaineer & Aviator 0 06-01-2015 11:07 AM
Leaking fuel line at filter dstraw 1973 - 1979 F-100 & Larger F-Series Trucks 2 12-01-2014 07:53 AM
in line fuel filter 86pullerf350 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 09-30-2014 03:53 AM
fuel pump w/ filter rockittsled 1973 - 1979 F-100 & Larger F-Series Trucks 7 02-20-2014 09:13 PM
Tags
02, 2002, assembly, bad, change, explorer, expolrer, filter, ford, fuel, located, location, pump, replace, symptoms, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
