351 cleveland
Welcome to FTE! More than likely you do not have a 351 Cleveland because they were discontinued in the early 70s. It is possible however that someone has put that 351C into your truck, in this case it is not the original engine. You more than likely have the 351M which is for the most part completely interchangable with the 351C and 400. The timing could be different for the 3 motors however. I really am not sure what the difference would be, I am more used to dealing with my 300 I6. I would try seting the timing to the specs for the 351M and then see how it runs, you might use that as a baseline and then fine tune the engine by ear. Good luck!
Here's a list of some ignition timing specs for 351M/400 truck engines:
http://home.earthlink.net/~bubbaf250/perf/perf10.html
Try posting in the "351M, 400, 351 Cleveland" engine forum for more help with the engine.
https://www.ford-trucks.com/forums/f...?s=&forumid=54
You more than likely have the 351m which is for the most part completely interchangable with the 351c and 400.
The truck would have to have been a 302 originally for it to slide in with not much work. An original 300 six truck would work too, but the frame perches would have to be changed. An original 351m/400 truck would have needed a different tranny to fit a 351c. In all cases, the exhaust downfalls would have to be fabricated amd custom fit for a 351c.
The 351M is a member of the 'Cleveland' family of Ford engines, so that's likely what you have. From the sources I've found, 1980-1982 is pretty much a crap-shoot for what engine you might have. This is the most succinct statement I've found:
"Ford began to gradually phase the M-block out of trucks from MY 1980 through MY 1982. Beginning in MY 1980, the 400 was dropped from the engine lineup for Broncos and F150 pickups. The 351M and 400 were dropped from all but the F250HD and F350 models by the end of MY 1981, and they were dropped completely at the end of MY 1982. "
In any case, the emission sticker on the radiator bracket should tell you exactly what engine the truck had, originally.
Originally posted by Franklin2
You would be surprised how much is NOT interchangeable. The heads and the waterpump, and the oil pan, and a few little things.
http://home.earthlink.net/~bubbaf250...history03.html
motor timing
to all who came back to me with there answer's i thank you . I just found out the other day that the org. motor was a 6 cly , the one that is in there now is a 351W '85 came out of a van.
Now ihave somthing to go on. Now to see what kind of juice i can get out it .thanks to all . if i have any more qust. i be back
I have three uncles who worked for ford
Yes I have three uncles who worked for ford from 1978 to 2011 and you're not correct about the 351 Cleveland been discontinued in the seventies it was not discontinued until 1983 in America however it was continued to be used in Australia up until 2001 I have an 80 f150 4x4 and it came from the Ford plant in claycomo Missouri with a 351 Cleveland
You are aware this thread is 17 years old right....
Yes I have three uncles who worked for ford from 1978 to 2011 and you're not correct about the 351 Cleveland been discontinued in the seventies.
It was not discontinued until 1983 in America however it was continued to be used in Australia up until 2001.
I have an 80 F150 4x4 and it came from the Ford plant in claycomo Missouri with a 351 Cleveland Impossible!
What's the VIN of this F150 4WD? The only Ford assembly plant in Missouri is located in Kansas City.
You know the Kansas plant is not actually in Kansas City, but just North East in Claycomo right.
And if the trucks were built for the AUS market they likly would have been fitted with Geelong cast 351C's at Kansas. The 302C/351C were used down under in trucks till 85 or so.
Below is a 351C equipped 81 F150
I do now...
And if the trucks were built for the AUS market they likely would have been fitted with Geelong cast 351C's at Kansas. The 302C/351C were used down under in trucks till 85 or so.
I do now...
If Kcak47mopr posts his trucks VIN, the truth will be evident for all to see.
Gary Lewis
37
08-28-2013 04:05 PM
maverickman514
27
03-18-2011 12:54 AM
c_cort
31
04-10-2008 01:41 PM
