1991 Explorer Armrest Removal
I'm trying to remove the center armrest on a 91 Ford Explorer XLT (front bench seat). I found one allen screw on the mount between the armrest and the driver's seat, but removing that didn't budge it. Are there other removal points before I get a crowbar out?
The more detailed the explanation, the better.
Thanks!
Thanks!
Got it, thanks. Had to do a bit of cutting into the foam to figure out what the bolt took. Turns out it's a "star" head, but an allen wrench worked. For anyone needing to do this, the cutting isn't necessary. Open the cover and pull it a bit back; there is a small hole on the passenger seat side of the foam. You'll need a rather long wrench to get in there. Didn't check the size...
truckmonger1
1999 to 2016 Super Duty
04-26-2012 03:55 PM
chrisbeery
10-08-2011 06:56 PM
