1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Air Conditioning vs. Other Vents?
Old 12-12-2003, 09:11 PM
v10kenj's Avatar
v10kenj
v10kenj is offline
I bought a new 2003 F250 SD with a V-10 about 6 months ago and althought this doesn't seem to be a problem, I'm wondering if the same thing is occuring with other trucks. On the heater/airconditioning vents, I have max ac, reg ac, and the other vents. On the one non-ac vent that directs air both towards the floor as well as the upper vents, if I put it in the cool position, the air conditioning comes on. The air gets very cold, and condinsation drips down from under the hood. If I put it on just upper vents, without the floor, all I get is outside air. Is it normal for the ac to work on any of the non max ac, or reg ac vents?
Old 12-12-2003, 09:26 PM
GreatWhite02's Avatar
GreatWhite02
GreatWhite02 is offline
I couldn't completely understand your question but, I'll try and shed some light. Ford has done away with the fresh air control. When using the defost by itself or on split level the ac compressor is running to aid in clearing the windshield.
Old 12-13-2003, 01:39 AM
Mwachel's Avatar
Mwachel
Mwachel is offline
Your AC will turn on for ALL settings except the "upper vent" only position.
First position to the left is the only NON AC one.
Old 12-13-2003, 10:13 AM
jdadamsjr's Avatar
jdadamsjr
jdadamsjr is offline
And actually I sort of understand this....
The a/c's on to dehumidify the truck...
And you can bet mine 'fogs' up quick without the a/c....
Old 12-13-2003, 03:08 PM
Mwachel's Avatar
Mwachel
Mwachel is offline
It is also good to run the AC in the winter to keep it lubed up and running correctly. With this set up you don't have to worry about remembering to run the AC once a month or so during the cold season.
I didn't like it at first but now it doesn't bother me at all. With these big trucks I don't worry about the gas mileage going down from running the AC anyway!
Old 12-13-2003, 08:39 PM
jdadamsjr's Avatar
jdadamsjr
I know there are a few diffrent levels of A'C units, but on my '03 Ex I CAN turn off the A/C compressor with the AC button,
but it WILL fog up in time just from the people breathing in the Ex, I guess ?!?!?
Old 12-13-2003, 09:44 PM
Mwachel's Avatar
Mwachel
Mwachel is offline
The newer Ford designs give you the option of having the AC with the button.
Old 12-15-2003, 03:21 PM
Shepard's Avatar
Shepard
Shepard is offline
Interesting because when my 2001 was new, I asked the dealer about not being able to switch from outside air to recirculated, except on max. a/c. He said it was one of the most frequent complaints they got about the new trucks. People in traffic behind or beside a diesel (biggest offender seems to be Dodge pickups), kept having to switch the system off to prevent the fumes from choking them.
Nice to know Ford listens and has put the option back on new trucks.
raye321
08-01-2014 06:20 AM
RickBraden
03-22-2012 06:48 PM
99RedExpy
1997-2006 Expedition & Navigator
02-07-2007 01:40 PM
schmittyhappens
09-23-2006 10:09 PM
jmailand
11-13-2003 12:14 PM
Quick Reply: Air Conditioning vs. Other Vents?
