Tires For Snow: Wide or Narrow - Page 2 - Ford Truck Enthusiasts Forums
View Poll Results: Which is Better for Snow, Wide or Narrow
Wide 15 28.30%
Narrow 38 71.70%
Voters: 53. You may not vote on this poll
Old 12-14-2003, 10:51 PM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Well, after nearly 40 years of driving where we get snow ICE and slush, -a narrow tire is best. Wide tires just slip-slide all over and go nowhere. I have driven both under all conditions. You do need some decent tread tho, baldies will not go well either.
Old 12-15-2003, 01:39 AM
Redneck-Cowboy's Avatar
Redneck-Cowboy Redneck-Cowboy is offline
Redneck-Cowboy is gaining momentum as a positive member of FTE.
It all has to do with how deep the snow is. Wide or narrow it won't matter to much with decently treaded tires as long as the snow is just brushing your axle. But once you start pushing snow with your axle and bumper your gonna want narrow to cut through drifts better. I've got pretty dang good 31x10.5's on my truck, but I've got worn out front coils so it doesn't sit so high anymore. So this weekend when we were playing in the 1/4 mile long, 3 foot deep hard drifts, I was losing in are little game between 4 trucks b/c I was pushing so much snow ahead of me. As long as it's below my bumper I do alright with wide tires, but the 90 Dodge 2500 with 245x16's came out on top.
Old 12-15-2003, 09:56 AM
tkd tkd is offline
tkd is gaining momentum as a positive member of FTE.tkd is gaining momentum as a positive member of FTE.
I would say NARROWER tires as opposed to widER tires. Recently, in some bad weather, I was in an Excursion, following a buddy in an F350 Dually. With experienced drivers driving within the limits, the F350 was in the ditch twice. The reason, more contact area and thus more "float". The excursion did fine. I know some will say that it was the weight of the truck and the open bed, etc.,, but from freinds up north, they say dually's have the hardest time and they should have the most contact patch.
Old 12-15-2003, 11:13 AM
fishmanndotcom's Avatar
fishmanndotcom fishmanndotcom is offline
fishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to all
Quote:
Originally posted by swann79
It all depends on the weight of the truck boys
it's always about the weight isn't it? hahahaha
narrow tires as long as there is a bottom to it.
-jason-
Old 12-15-2003, 02:43 PM
highboy 74's Avatar
highboy 74 highboy 74 is offline
highboy 74 is gaining momentum as a positive member of FTE.
Narrow tires are better for compact snow and ice. But wider tires are better for driving in deep snow as they tend to float better.
Old 12-15-2003, 06:51 PM
swann79's Avatar
swann79 swann79 is offline
swann79 has a very good reputation on FTE.swann79 has a very good reputation on FTE.swann79 has a very good reputation on FTE.
Quote:
I sure do wish I wasn't as heavy!
Wait a minute... are we talking about trucks or beer bellies?
Old 12-15-2003, 10:17 PM
cdtruckn's Avatar
cdtruckn cdtruckn is offline
cdtruckn is starting off with a positive reputation.
Let's see, snow cat's have............WIDE TRACKS and what do snowmobiles have? WIDE TRACK. Any rocket scientists out here?
Old 12-15-2003, 11:42 PM
Quote:
nope just pure experience
-jason-
Old 12-16-2003, 01:08 AM
85351ho 85351ho is offline
85351ho is starting off with a positive reputation.
cause they are designed to stay on top in deep snow
whic his why wide tires kick butt in deep snow
skinny is the way to go in slush/packed junk on the road
Old 12-16-2003, 01:17 AM
Broke n' Down Broke n' Down is offline
Broke n' Down is starting off with a positive reputation.
As a lifelong resident of Alaska, I have had several trucks and experimented with both wide and narrow tires. They both have there advantages and disadvantages. Narrow tires are good when you are driving in fresh snow on a road surface, because the track really nice and don't pull you around like wide tires. If you get at all on the shoulder they will pull you off the road quicker than a 460 empties a tank of gas. However, if your breaking trail where your tires can't dig down to earth, wide tires are the way to go because they provide floatation. If you get on a side hill, your screwed. So to answer your poll, It depends!
Old 12-16-2003, 09:35 AM
No_BS's Avatar
No_BS No_BS is offline
No_BS is starting off with a positive reputation.
I'm aggreeing with the more psi contact to the ground, my 10.50's are unstoppable in the snow.
Old 12-16-2003, 12:17 PM
rrawlins's Avatar
rrawlins rrawlins is offline
rrawlins is starting off with a positive reputation.
I'm surprised no one has mentioned siping and tread compound which are the 2 most important factors when dealing with traction on snow and ice. Wide tires do provide some flotation but to think 320 sq in. ( 4 tires with 80" of surface contact per tire) of road contact will float a 5000 lb truck in three feet of snow is pretty silly, as is thinking skinny tires will dig down to the ground. In either case your going to be high centered. If you want to do it right you get a set of dedicated winter tires in the stock size and put them on steel rims...and carry a shovel, tow strap, sand, chains, winch, etc. to cover the situations that NO tire, thick or skinny, will cover. All good winter tires will have lots of siping (the cuts and grooves in the tread) and a very soft compound. Bridgestone's winter duelers will actually squawk on ice because they are so sticky but their ultra soft compound means they wear very quickly. Any serious winter tire will be labelled "meets the severe snow service requirements of the blah, blah, blah..." The bottom line is that no single tire will cover you for all types of snow and ice but a dedicated winter tire in the stock size is the best compromise.
  #28
Old 12-16-2003, 01:36 PM
bubbaf250's Avatar
bubbaf250 bubbaf250 is offline
bubbaf250 is starting off with a positive reputation.
Doesn't take a rocket scientist to figure this out...
The heaviest regular production tracked snow vehicle (Thiokol Juggernaut, 16K lbs payload, 36K lbs GVW) exerts ground bearing pressure (GBP) of 2.3 psi at max GVW. Typical GBP for a Sno-Cat type vehicle is 0.5 to 1.25 psi.
Tracked snow vehicles are a completely different application, irrelevant to this discussion about truck tires. Full floatation (zero penetration) on snow is virtually impossible with any tire that you could use on a street-legal pickup truck.
Any idea what tire size you'd need to get GBP down to, say 2 psi, on a 6000 lbs (empty) F250? (Hint: at least double the size of a Super Swamper TSL 18.5/44-16.5.)
Yep, they kick your butt all the way off the side of the road and into the ditch.
Quote:
I'm aggreeing with the more psi contact to the ground...
That is the opposite of "flotation." Now for you rocket scientists out there, that means more force per area, or...
Narrower tires.
  #29
Old 12-16-2003, 01:56 PM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is offline
Ryan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to behold
This argument will go the same way of an auto vs. manual transmission argument. It all depends on what you like driving on.
  #30
Old 12-16-2003, 05:18 PM
proeliator proeliator is offline
proeliator is a splendid one to beholdproeliator is a splendid one to beholdproeliator is a splendid one to beholdproeliator is a splendid one to beholdproeliator is a splendid one to beholdproeliator is a splendid one to beholdproeliator is a splendid one to behold
Well, I wasn't going to wade in but it seems that you need a word from the All Knowing One. In deep, soft, snowy conditions...wide tires are best. On icy, or hardpacked glazed snow conditions...skinny tires are best. I think Ho was trying to say the same thing. BUT since there isn't a best answer to this, this thread can just go on and on, much like Ryan said. But, now that I've added my two cents we can put this debate to rest.
Right?
Michelin ltx m/s2 or at2? BrianF-250 1999 to 2016 Super Duty 32 03-06-2014 05:04 PM
Better traction-front or back tires more impt? eriklane 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 12-07-2011 09:02 PM
Skinny tires vs wide for snow? swamprat Brakes, Steering, Suspension, Tires, & Wheels 2 11-12-2005 09:55 AM
6" Lift & 40" tires, good in snow? RyanGruhn 1978 - 1996 Big Bronco 20 02-18-2003 04:39 PM
Tires/Rims (transplanted from general forum) Greywolf Brakes, Steering, Suspension, Tires, & Wheels 1 10-19-2001 08:59 PM
Tags
245x16, 38514515, 4trucks, best, deep, game, google, ilve, juggernaut, lt, narrow, snow, thiokol, tires, vehicle, wide
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
