Picture of Freeze Plug Location ?
Could anyone post a picture of the freeze-plug locations on a 3.0 V-6 ?
Both the Head and the Block.... I have a leak that I can see and i'm thinking its a freeze plug.
I have one of the Ford Factory Service CD's, but they are such a pain to search for something, you just about have to stumble across it to find something.
A total of 9 freeze plugs....
1 in each ends of the heads = 4 at 1 1/4" ,
2 at the end between the block and Transmision = 2 at 1 1/2",
3 in the sides of the block 2 on one side and 1 on the other by the motor mounts = 3 at 1 1/2"
For a total of 9
4 - 1 1/4" 5 - 1 1/2"
If you replace one, replace them all. Make sure you replace them with Brass ones.
For a total of 9
Pagemaker:
Try this....
http://home.inreach.com/jthill/aerostar/engine.html
I put up some pictures of the freeze plugs locations. They are easy to see. Shiney Brass.........
Try this....
Thanks for everyones replies to this topic, I've found that I don't have a freeze plug leak.
JT I really appreciate the breakdown of that aerostar in your website... thats awesome, I quess I should start taking pictures of my projects too, it may make someone elses life easier with the aerostar. Keep up the good work, I'll be checking your site regularly!
bluegrass65
13
04-05-2020 12:48 PM
1954blueoval
11-06-2007 02:48 PM
