Picture of Freeze Plug Location ? - Ford Truck Enthusiasts Forums
Aerostar Ford Aerostar
Old 12-12-2003, 06:29 PM
Pagemaker's Avatar
Pagemaker Pagemaker is offline
Pagemaker is starting off with a positive reputation.
Exclamation Picture of Freeze Plug Location ?
Could anyone post a picture of the freeze-plug locations on a 3.0 V-6 ?
Both the Head and the Block.... I have a leak that I can see and i'm thinking its a freeze plug.
I have one of the Ford Factory Service CD's, but they are such a pain to search for something, you just about have to stumble across it to find something.
Old 12-13-2003, 01:37 AM
Berry Berry is offline
Berry is starting off with a positive reputation.
Just for your information, there are a couple of freeze plugs that are on the back of the engine, behind the bell housing. ( Have to remove transmission to reach them.) There are also a couple on the back of the heads I think.
Old 12-13-2003, 02:24 AM
JTHill24 JTHill24 is offline
JTHill24 is starting off with a positive reputation.
A total of 9 freeze plugs....
1 in each ends of the heads = 4 at 1 1/4" ,
2 at the end between the block and Transmision = 2 at 1 1/2",
3 in the sides of the block 2 on one side and 1 on the other by the motor mounts = 3 at 1 1/2"
For a total of 9
4 - 1 1/4" 5 - 1 1/2"
If you replace one, replace them all. Make sure you replace them with Brass ones.
Old 12-13-2003, 04:43 AM
rlmdad rlmdad is offline
rlmdad is starting off with a positive reputation.
John,
Agree with Jay, replace one, replace all and def. use brass replacements.
LOL - Happy Holidays to you and yours.
Ron
Old 12-13-2003, 05:59 PM
Pagemaker:
Try this....
http://home.inreach.com/jthill/aerostar/engine.html
I put up some pictures of the freeze plugs locations. They are easy to see. Shiney Brass.........
Old 12-14-2003, 12:13 AM
Pagemaker's Avatar
Thanks for everyones replies to this topic, I've found that I don't have a freeze plug leak.
JT I really appreciate the breakdown of that aerostar in your website... thats awesome, I quess I should start taking pictures of my projects too, it may make someone elses life easier with the aerostar. Keep up the good work, I'll be checking your site regularly!
freeze plugs?? lucky_strike 1967 - 1972 F-100 & Larger F-Series Trucks 29 10-07-2010 11:09 AM
Freeze Plug JO7 Escape & Escape Hybrid 0 07-25-2010 03:50 PM
223 Freeze Plugs 1954blueoval Ford Inline Six, 200, 250, 4.9L / 300 3 11-15-2007 04:34 PM
223 engine freeze plugs 1954blueoval 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 11-06-2007 03:48 PM
1987 302 f150 freeze plugs bluegrass65 1987 - 1996 F150 & Larger F-Series Trucks 11 12-11-2006 07:23 PM
Tags
289, 30, 302, 40, core, engine, ford, freeze, head, heads, location, locations, picture, plug, plugs, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
