DRL Module Location?? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-12-2003, 11:15 AM
elkfever elkfever is offline
elkfever is starting off with a positive reputation.
My 2000 F350 was originally sold in Canada, and is equipped with Daytime Running Lights (DRL).
I want to disable that feature, but am unable to find the DRL Module. I did identify the DRL Resistor which is located behind the driver's side headlight (as per Ford information). Ford information shows the DRL module to be located behind the glove box; I have removed the glove box, checked both sides of the firewall, but am unable to find the module.
Can anyone identify the module location please.
Any information will be appreciated.
Thanks
Old 12-12-2003, 11:54 AM
oppy's Avatar
oppy oppy is offline
oppy is starting off with a positive reputation.
Why do you want to disable them? I kinda like mine.
I'll check my service manual when I get home and let you know if someone hasn't already.
Old 12-12-2003, 12:17 PM
Oppy,
I purchased a disabling adaptor from TYMAR for $8, and just want the option of running without daytime lights (for example when driving into hunting camp). Any info you can provide from your service manual will be appreciated.
Thanks
Old 12-12-2003, 12:48 PM
oppy's Avatar
Good idea - never thought of that. So, the Tymar adapter is some kind of switch, or?? Sounds like a decent cheap investment.
Old 12-12-2003, 01:48 PM
Oppy,
The adaptor is a Ford part. Dale Isley at Tymar mentioned he had the used adapter plug when I ordered a Tymar Intake System for my Powerstroke Diesel. The adapter plugs into the wiring harness in place of the DRL module. You could probably obtain the part directly from Ford for their retail price of $16. Sorry but I do not have a part number, but the adapter plug is stamped FOEB-14A624-A.
Old 12-13-2003, 09:16 AM
oppy's Avatar
Sorry I took so long to get back to you.
According to my service manual, the DRLs have 2 relays, both of which are at the left rear of the engine compartment in Auxiliary Relay Box 2.
I don't have a good diagram of it, but you should be able to tell which one you need by the pin configuration.
There is also a resistor near the left side headlight, but you already found that and it's not what you were looking for.
Good luck, and let me know how it works.
Old 12-22-2010, 09:50 PM
erniek70 erniek70 is offline
erniek70 is starting off with a positive reputation.
Is there an actual DRL module, or just the relays only? My headlights are not working properly (no low-beams, and high beams only with the manual headlight switch). I was told it MIGHT be the DRLs causing it. Any ideas?
Old 12-23-2010, 05:19 PM
bunklash's Avatar
bunklash bunklash is offline
bunklash is gaining momentum as a positive member of FTE.
"......just want the option of running without daytime lights (for example when driving into hunting camp)"
Is that because the elk can hear you coming if the DRL's are on?
Old 12-23-2010, 06:14 PM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
"FORD F-150 Trucks Replace the DRL relay (located top of pass side dash) with a loop back plug (or modify it). But first try unplugging the dropping resistor (located at Left front of truck, underneath)."
DADRL - How To Disable DRLs
On my E series, unplugging the DRL module behind the grill did it.
Old 01-03-2011, 05:03 AM
removed switch, then re-installed. all lights worked for a bit, then low-beams stopped working again! DRLs are not working either.
Old 01-03-2011, 05:18 AM
Anyopne know where the DRL is on an '05 SD? Are they only controlled by the relays under hood? An actual module somewhere? Could it be the source of my problem?
Old 04-17-2013, 11:02 PM
Ace_boy2786 Ace_boy2786 is offline
Ace_boy2786 is starting off with a positive reputation.
There is no DRL Modules, only 3 relays tied into the headlights and a resistor. I am currently looking inot hooking them up but instead of to the headlights sending the DRL signal to the fog lights.
Old Today, 02:32 PM
jm-bc jm-bc is online now
jm-bc is starting off with a positive reputation.
The relays are located above the glovebox on my 2000 F350. There are three bolts on the base of the glovebox. $1 to remove the bolts - $99 to know what bolts to remove. Ford did not make this obvious.
2005-2007 DRL relay and resistor location rxk9394 1999 to 2016 Super Duty 10 09-30-2016 06:36 PM
2000 f450 diesel daytime running lights install where is the module? wbanf 1999 to 2016 Super Duty 1 06-06-2011 06:09 PM
2007 F150 wiring diagram fordmanss12 Electrical Systems/Wiring 8 06-19-2007 10:52 PM
Daytime Running Lights DRL xpanmanx 1997-2006 Expedition & Navigator 17 10-13-2003 08:43 AM
97 F350 DRL Module location joyedco Electrical Systems/Wiring 5 10-06-2003 05:28 PM
Tags
14a624a, 1997, drl, duty, f150, f250, foeb14a624a, ford, located, location, module, powerstroke, ranger, resistor, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
