body part interchange - Ford Truck Enthusiasts Forums
Old 12-11-2003, 12:37 PM
Manwith3fords's Avatar
Manwith3fords Manwith3fords is offline
Manwith3fords is starting off with a positive reputation.
I need 2 new (used) doors and a rad support for my 88. What other years will fit? I was told the doors from 80-96 will fit, is this true? I plan on buying 2 new front fenders rather than search for rust free ones, rust free is a fantasy up here on the east coast of Canada. Can you still buy the rad support bushings (mounts) ? I'm going to do the body up on my truck for paint and I want to start collecting some replacement stuff.
Old 12-11-2003, 03:17 PM
gatesj gatesj is offline
gatesj is starting off with a positive reputation.
Doors/cab are same 80-96. Anything forward of the cab is same between 80-86, 87-91 and 92-96. They will not interchange between these three styles unless you do it all, in which case I'm told it's a no-brainer bolt-up. People have put all the 92-96 body parts on their older trucks and updated the look. Box is the same 80-86 and then from 87-96. There are subtle differences in the lines between the two styles but nothing major.
Old 12-13-2003, 05:16 PM
rolledover89 rolledover89 is offline
rolledover89 is starting off with a positive reputation.
what do you mean, the box? i have a rolled over 89 F-150, and i have a 82 cab, will the cab bolt up? all i need is the new cab, so will the 82 bolt up, with my 89s fenders?
Old 12-13-2003, 05:58 PM
From what I've *heard*, it should. You might have to make holes in the firewall and some other adaptations to make it work but I hear it should fit.
By "box" I mean the part behind the cab.
Old 12-13-2003, 08:30 PM
o, okay, thanks
Looking to buy Nose is 1961 - 1966 F-100 & Larger F-Series Trucks 5 01-11-2016 04:52 PM
Radiator Core Support DougJ_1997PSD 1994.5 - 1997 7.3L Power Stroke Diesel 1 06-25-2015 07:22 PM
Radiator support compatability mr.fordneck 1987 - 1996 F150 & Larger F-Series Trucks 5 05-13-2013 08:43 AM
94 f250 gas rad & 94 f250 diesel rad enosez 1987 - 1996 F150 & Larger F-Series Trucks 0 04-02-2013 04:46 PM
Rad Support mount tip49 1948 - 1956 F1, F100 & Larger F-Series Trucks 41 04-25-2005 02:33 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
