ati prochargers fpr
ati prochargers fpr
i have been looking at an ati procharger. the main thing about the system is that they use a fuel pressure regulater on the fuel. if i am right it about x4 or around that psi on fuel rail for every psi of boost. i have 19 lbs injecters on my 4.6l f150. is this a sound way to add more fuel for the boost it adds? i just don't want to buy and have to go back though there system and buy more to make it work right. any info on the system as far as install and the way it works will be helpfull in my research on this system. i have the info pack from ati on the charger and have called them on the phone but they ( being the person i talk to ) did not sound like she had that much tech experiance. but i could be wrong.
thank for any info.
furrby
thank for any info.
furrby
I don't like FMU's in general, Get bigger injectors, MAF, and a Chip from a reputable tuner. I've seen FMU's fail and its not pretty. Guess what happens when you loose fuel pressure under boost, nothing if you are lucky but usually piston damage. I'm a firm believer in doing things right the first time.
Burple
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
07-28-2008 01:34 PM
F250SD
09-06-2004 08:45 AM
