Clutch problems. Need help!
Howdy all,
I was curious if there's some way of checking the function of the clutch master cylinder on my '90 F-150. It's got a Mazda 5 speed sitting behind an I6. The clutch assembly is only 5 months old, but I suspect the disc is a cheep one. Lifetime warrentys don't get the tranny back down regretably.
The slave cylinder was replaced at the same time so I'm wondering about the master cylinder. It's the only thing I didn't replace and now it won't go into gear while running. The peddle is soft, but it lurches forward when in gear and the key is turned.
I'd be greatful for any ideas.
Thanks,
-John R.
Thanks,
-John R.
Everything was fine this morning at 4:45 am. I had hell to pay to get the truck to move 10' thanks to the mud/ice/snow mix on the ground. I gave up until daylight to put on some studded snow tires. When I fired the old girl up, no engagement.
I put it in gear with the engine off. I then craked the key and it lunched forward. Whatever was hung up gave loose for about 2 minutes, then it wouldn't go into gear at all with the eninge running. The cranking while in gear trick doesn't work anymore either.
The clutch fingers are bent now some. I did try and rebleed the line. No luck there, it bled fluid. The master cylinder is full and not leaking. I only suspect it because there's no peddle resistance.
If you've got any specific questions on something I left out, please feel free to ask!
Thanks Eddie,
-John R.
Thanks Eddie,
-John R.
Well John,
Sounds like you did some serious damage this morning. It sound to me like the Clutch disc fell apart and went into the pressure plate. You must have heard some noise from the clutch area before it went afu? The reason the pedal is soft is because the throwout bearing has no resistance to push against it. More than likley you will have to replace the disc. pressure plate, throwout bearing, and slave cylinder. Resurface the flywheel also. Maybe since the slave cylinder is not tha old and (you are in good standing with you auto parts supplier) you may get it exchanged for a new one. Once you pull it all apart you will see the damage. Do not forget to put in the right Tranny fluid. Consult the owners Manual. Some Ford Manual trannys take ATF
