Gas Mileage on FE's
Old 12-10-2003, 03:56 PM
65f100CoryE.'s Avatar
65f100CoryE.
65f100CoryE. is offline
Unhappy Gas Mileage on FE's
Whay doe severy one think that FE's are so hard on gas?
I have 5 of them 352, (2 360's), 390, and 428. I have never gotten worse than 15mi/gal with any of them. (driving reasonably)
Old 12-10-2003, 05:14 PM
Ratsmoker's Avatar
Ratsmoker
Ratsmoker is offline
I have gotten 12 with mine as it sits in on my FTE webpage.
Old 12-10-2003, 08:01 PM
76390FE's Avatar
76390FE
76390FE is offline
65f100CoryE., that is pretty good mileage...but I don't doubt that it can't be done. What transmissions do these trucks have in them. My 390 gets about 10 mpg, but I also think that part of my problem is the C-6 wastes some of the power. Do you have any tricks (besides a good tune-up) for getting better mileage out of an FE?
Thanks
Old 12-10-2003, 08:45 PM
gtex's Avatar
gtex
gtex is offline
Cory, you must be using some of that Enron math. I've never gotten 15 MPG in any FE powered ford. 352, 360, 390 and don't even think about this 428 stroker.
Old 12-10-2003, 08:51 PM
rusty70f100's Avatar
rusty70f100
rusty70f100 is offline
Hey, I get 15mpg out of my truck on the highway. See sig. I dont think my calculator was made by Enron?
Old 12-10-2003, 09:18 PM
gtex's Avatar
gtex
gtex is offline
What gears are you guys running? I might have gotten close to 15MPG in my 68 F100 with the 360 and dual exhaust.
Both my newer trucks are F250s with 4.10:1 gears....They are humming on the highway at about 3400 RPM. Gulp Gulp Gulp
Old 12-10-2003, 09:20 PM
rusty70f100
I'm running 3.73's with P265/75R15 tires.
Old 12-10-2003, 09:38 PM
fordman428's Avatar
fordman428
fordman428 is offline
before i tore down my 390 at the time stock 2 barrel dual exhaust, i would be lucky to get 10 mpg but i have a heavy foot i dont want to imagine what its going to be like when im done with it. good thing it has dual tanks.
Old 12-10-2003, 10:18 PM
65f100CoryE.
Well I will start with the Ltd I had, since it would be the most difficult to believe.
It was a 390 4bbl I used 1 step up from an RV cam and (comparable to the CJ cam)
I had 2 1/4 dual with short glass packs. It was a C6 tranny, I am not 100% what the gears
were but they were really great on the hiway @ 75Mi/Hr the tach was barely touching 2200rpm.
My 65 is 3.25 gears with NP435 4spd I use P275 60R15 tires 2 1/4 dual with strait pipes
9.5:1 compression with decent cam .512lift .538 lift 292/302 durration.
factory style motorcraft 4300 4bbl.
I am not sure what the deal is. I know free flowing exhaust is a must.
As for the "enron math" maybe the calcs are different in canada
4.54 instead of 3.7L / Gal helps I think too.
I know that I can get just around 270Miles on the tank in my 65.
Old 12-10-2003, 10:22 PM
Scouder's Avatar
Scouder
Scouder is offline
Aw c'mon Gtex,
We still use slide rules here in WY, so I know my math is right. Before I tore this project truck apart I commonly got 15mpg. 76 F250, 390, 4.10, 35" BFG's at about 2650rpm cruise. And that is at 7000 feet!
-Scouder
Old 12-10-2003, 10:57 PM
fordfan428's Avatar
fordfan428
fordfan428 is offline
Before I bought truck from my in-law's( many years ago, in fact I have owned it longer then they did) they said they got 15-16 mpg..I natually upgraded the cam, intake, carb., ign., and exhust right away and have been getting 10mpg since, of course I drive a little different then they did..LOL..This is a 74 F100 360 4x4 (man. hubs) 4sp 3.50 gears and 31" tires..
Old 12-10-2003, 11:12 PM
Rat wagon's Avatar
Rat wagon
Rat wagon is offline
I used to get 15-18mpg@65mph outta my 72 390 w/600cfm holley when it had 3.54 gears.... believe it or not
adjusted brakes, nice wheel bearings, tight driveline, adjusted carb, and decent ignition system will keep an Fe above the 10mpg mark atleast.
Old 12-11-2003, 12:37 AM
Crumm's Avatar
Crumm
Crumm is offline
I get about 4mpg with my 390. This is short trips in cold weather with 10-15 minutes of idle warm up (-20 deg out). There is also a little snow plowing thrown in there too. I am glad to hear that I might be able to get 10mpg next summer.
Old 12-11-2003, 08:19 AM
Freightrain's Avatar
Freightrain
Freightrain is offline
I get avg 12 with mine. It has 3.25 gears and a toploader 4spd hooked to a stock 352(750 holley). It got 11 with autolite 2bbl.
I run it around 3000 rpm on the highway(275/15 BFG) to keep up with traffic(around 70 mph). I know if I would cool it a bit I might get 1-2 more. Can't do that though.
Larry
Old 12-11-2003, 08:27 AM
gtex's Avatar
gtex
gtex is offline
Scouder,
Although your 35s carry a bit more weight, they are making your 4.10s look something like a 3.45:1 gear ratio. Throw some 255-70r16s on there and see what happens to our highway RPM and gas mileage.
Quick Reply: Gas Mileage on FE's
