Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-09-2003, 08:26 PM
56f600 56f600 is offline
Garage is empty, add now
56f600 is starting off with a positive reputation.
exhaust manifolds
My '37 has two different type of exhaust manifolds. One side dumps straight down on the front end of the engine. The other side dumps at an angle about a third of the way back. This side is aimed right at frame. The truck came with no other exhaust and I'm wondering what I've got. Ideally a mirror image to the front dump would work good for routing the new exhaust. Any suggestions?
__________________
Mark
1956 F600
flatbed dump
  #2 (permalink)
Old 12-11-2003, 05:57 AM
4tl8ford's Avatar
4tl8ford 4tl8ford is offline
4tl8ford has a great reputation on FTE.4tl8ford has a great reputation on FTE.4tl8ford has a great reputation on FTE.4tl8ford has a great reputation on FTE.
Check out the site below
I'm not up on the early engines, but what you described sounds about right.
There are diagrams of all flatmotors and associated parts
http://www.vanpeltsales.com/FH_web/flathead_home.htm
__________________
Dick C
Erie, PA
1948 Ford F1 Panel
1952 Ford F2 (Non-Stock Flat 6)
1997 Ford Explorer
Every Thing I've Ever Said Is A Lie
  #3 (permalink)
Old 12-18-2003, 06:19 AM
Steve_B's Avatar
Steve_B Steve_B is offline
Steve_B is gaining momentum as a positive member of FTE.
Hi Mark
What you have is the standard setup
The pipe from 1 side comes under the front of the engine then meets the pipe from the other side before exiting via a single pipe
I have the same but my truck is right hand drive so the opposite way around, I got a pair of left hand drive manifolds so will have a matched pair for a twin exhaust system
Maybe you could find a right hand drive manifold
Stephen
Tags
exhaust, flathead, fprd, manifolds, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
