Go Back   Ford Truck Enthusiasts Forums > General > General Automotive Discussion
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 12-09-2003, 03:12 PM
78fordman's Avatar
78fordman 78fordman is offline
78fordman is starting off with a positive reputation.
speedo calibration
Do i have to take my speedo in to calibrate it, or is there a way to get it close my own?
__________________
2000 F-150 4WD Auto, 5.4, ex Cab
1970 f-100 2wd, 4 speed, 425hp 390
Proud To Be a High Plains Drifter
Tried true 'n blue
  #2 (permalink)
Old 12-09-2003, 05:38 PM
Marty Schwartz Marty Schwartz is offline
Marty Schwartz is starting off with a positive reputation.
Actually pretty straight forward.
1. Drive down the road and compare your odometer reading to a marked distance. Best bet is 10 miles on the interstate. If your odometer shows approximately 10 miles travelled then you are done. Other wise you will need to do the rest.
2. Pull the spedo-drive gear off the tranny end of the speedo cable and count the number of teeth.
3. The difference is a straight ratio. Namely a/b=c/d, where:
a=Counted number of teeth on the drive gear
b=Number of teeth that should be on the drive gear
c=distance recorded on odometer
d=measured distance travelled.
For example, if you counted 32 teeth on your speedo drive gear, you travelled a measured distance of 10 miles and your odometer indicated you travelled 11.1 miles then:
32/b=11.1/10
b=32(10/11.1)
b= 28.8 teeth required.
so you would need to replace the drive gear with one with 29 teeth.
Hope this helps.
Marty....................
  #3 (permalink)
Old 12-23-2003, 03:52 PM
78fordman's Avatar
Where can i get speedometer gears?
__________________
Tried true 'n blue
  #4 (permalink)
Old 12-23-2003, 10:15 PM
bkpf100 bkpf100 is offline
bkpf100 is starting off with a positive reputation.
Get the gears at dealerships or check yellow pages for speedometer calibration shop, they have them. One tooth change is worth about 3 mph change.
I use the mile markers on a flat stretch of interstate and a stopwatch. Hold the speedo real steady for the mile while a friend gets the stopwatch times between the mile markers.
3600 divided by the seconds = true mph.
Compare that to what you held your speedo on. Repeat a couple more times to get a good average.
  #5 (permalink)
Old 12-23-2003, 10:34 PM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold
One thing to remember is that speedo calibration is set for 1000 revolutions of the cable per mile. If the odometer is close but your speed is not you may need a new speedometer head. Speedo heads are available in junkyards, our classifieds sometimes and on eBay.
__________________
"Beam me up Scotty. There's no intelligent life down here..."
  #6 (permalink)
Old 03-06-2005, 01:07 AM
gingerbreadmaniac gingerbreadmaniac is offline
gingerbreadmaniac is starting off with a positive reputation.
another thing to keep in mind is if you have a GPS unit or can borrow one, at 55 mph these are very accurate for distance and speed...
-gbm-
__________________
77.5 camper special f250 (450 hp) 460 4x4 4spd braden 10,000 ib pto winch aftermarket steel steepside box. 700 watts worth of aircraft landing lights (driver)
79 camper special f250 2wd 429 auto (parts)
78 camper special f250 4x4 4spd ext cab 460 dana 60 front end (parts)
77 f150 300 I6 4x4 4spd (parts)
79 f150 300 I6 2wd 4spd (bought new in 79 by father, for resto one day)
  #7 (permalink)
Old 03-06-2005, 02:54 PM
fatherdoug's Avatar
fatherdoug fatherdoug is offline
fatherdoug is starting off with a positive reputation.
National Parts Depot(a sponsor of this site) has a good explanation of how to determine corrections for speedometer differences and also sells the gears. The writeup is in their mail-order catalog. I don't know if it would be listed on their website.
  #8 (permalink)
Old 03-06-2005, 03:27 PM
mark a.'s Avatar
mark a. mark a. is online now
mark a. is gaining momentum as a positive member of FTE. mark a. is gaining momentum as a positive member of FTE.
C.J. Pony parts has spedo gears too.
__________________
'79 F250 13" lift 42" Super Swampers
  #9 (permalink)
Old 08-19-2007, 04:03 PM
michaeljoe6 michaeljoe6 is offline
michaeljoe6 is starting off with a positive reputation.
I got a set of gears from a supplier on Ebay a few months ago.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
