Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford ExplorerSPONSORED BY:
Is F-150 Still King?
  #151 (permalink)
Old 03-05-2009, 10:09 PM
JCEXPLORER JCEXPLORER is offline
JCEXPLORER is starting off with a positive reputation.
Key pad code change Ford Explorers
Quote:
Originally Posted by 4mytruck View Post
does anyone know if i am missing some instructions or something when it comes to programming the keyless key pad??
(see previous post)
please close attention to the time frame.
Don't press the numbers in rapid succession.
Wait a second between each # but not more than 5 seconds.
If you miss you need to wait more than 30 seconds for the system to reset it self before you can proceed with the new try.
Key in the factory code
wait a sec and key in the 1/2 key,
wait a sec and key in the first # of the new code,
wait a sec and key in the next # of the new code and so on until you've finished and then the system should lock and unlock the doors.
If this works you will be able to use your new code rembering to key each # within the 5 sec time limit.
After keying in the new code you should hear the driver door unlock and you need to key the 3/4 key within the 5 sec time limit and that should open the rest of the doors and/or then the 5/6 key if it has a function for the rear glass only.
Try that.
  #152 (permalink)
Old 03-26-2009, 09:43 PM
Red Devil Fire Red Devil Fire is offline
Red Devil Fire is starting off with a positive reputation.
2005 Explorer XLT 4x4
SUV only a week old....no keyless numbers in the glove appartment/manual. The manual does say that the codes can be retrieved by looking on the side of the computer moduel. I have not
torn the compartments apart, trying to make sure where the computer
moduel is. Will save having to go to the Ford dealer. Any info? Thanks
  #153 (permalink)
Old 03-27-2009, 11:33 AM
2005 Explorer XLT 4x4 Keyless pad number locatiion
Sowaxeman:
You can add the 2005 Explorer to your list. You had perfect instructions.
Followed them to the "T" and got my number. 5 minutes is right on, start to finish. Saved me some $$.
The only thing though, I did not have a beer when I was done.
It was not "high noon" yet, although the wife always tells me that it
is noon "someplace".....
Thanks again, and have some nice summer driving!!
  #154 (permalink)
Old 06-08-2009, 12:26 PM
ThatsMrsJ ThatsMrsJ is offline
ThatsMrsJ is starting off with a positive reputation.
Thank You Very Much I found the code for My 1998 Ford Explorer I moved the jack and used a mirror and flashlight to find it
  #155 (permalink)
Old 06-17-2009, 12:47 PM
beerstud beerstud is offline
beerstud is starting off with a positive reputation.
2004 Explorer Sport Trac code
Quote:
Originally Posted by r_leann2006 View Post
Where would the code be for a 2004 Sport Trac?
Does anybody know where this code is located? I bought my truck used and dealer wants $92.00 for this!! I am not happy and certainly do not wish to give them this for something they should do for courtesy and that I can likely find myself.
Thanks,
  #156 (permalink)
Old 06-17-2009, 07:06 PM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero is gaining momentum as a positive member of FTE.
The Sport Trac code is behind the passenger air bag. Pop the defroster vent panel off, and from the outside look through the windshield into the area under the dash pad. You'll see a white box and a label on that box. That label has the 5 digit code printed on it. You'll need a good flashlight.
__________________
________________________________
"Information is valued and appreciated...Attitude is not!"
Steve,
'98 F150 Super Cab 4x4 SOLD, '99 Mustang 35th,
'02 Sport Trac 4x4, '01 Sport Trac Job 2 donor vehicle
'08 E250 Super Duty, No more Ranchero
  #157 (permalink)
Old 06-18-2009, 09:19 AM
Thanks
Will try to locate
  #158 (permalink)
Old 10-25-2009, 09:14 PM
nadrehctub's Avatar
nadrehctub nadrehctub is offline
nadrehctub is starting off with a positive reputation.
Quote:
Originally Posted by cvilla View Post
I looked all over for it and finally found it.
On your dash against the winshield, pop off the defogger cover panel, lay on your hood and shine a flashlight into the opening on the passenger's side. You will find the module there and the 5 digit code, printed on the right side of the sticker in bold print...hope this helps
This method worked on my friends 01' explorer sport 2dr.Did not have to mess with the air bag!!!! Thanks for the info!!!!!!!!
  #159 (permalink)
Old 10-31-2009, 05:06 PM
GAGDAD07 GAGDAD07 is offline
GAGDAD07 is starting off with a positive reputation.
Def. Vent Removal ?
Quote:
How big a deal to "pop off" the defroster vent, looks like it is connected with clips?, or something. What tool would I need to use ?.....Mine on a 2005 Sport Trac
looks to be in one piece, I don't want to break it....
.Thanks.........."G"
  #160 (permalink)
Old 10-31-2009, 07:34 PM
ncranchero's Avatar
The best tutorial I've seen is here:
2004: Keyless Entry Code - Ford Explorer Ranger Enthusiasts "Serious Explorations"®
__________________
Steve,
  #161 (permalink)
Old 11-14-2009, 05:43 PM
Unhappy Did Not Find Mine !
I popped the defroster vent panel on my 2005 Sport Trac, no white box that I could see. I did see the plastic defroster vent ducting, also blocking any view under the dash pad. I guess I'll keep searching other locations, or just spring for the $68-$75 fee that the dealer wants to hook up his computer ....... "G"
  #162 (permalink)
Old 11-14-2009, 06:05 PM
ncranchero's Avatar
It's not easy to see but according to the 2005 Ford Wiring Manual I just checked it is still located in the same place as the other year Sport Trac's. Here is the view from the passenger seat with the air bag removed.
__________________
Steve,
Tags
2002 , code , codes , entry , explorer , f150 , factory , ford , guide , keyless , location , prime , program , truck , unlock , xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
