is it a clutch or tranny problem?
HELP! ADVICE IS NEEDED
I have a 1994 4x4 F150 with a manual tranny and about 65K original miles.
Here's the question; When I let the clutch out in second or third gear and push on the accelarator the engine RPMs pick up but the speed doesn't increase for about 2 or 3 seconds, then it kicks in.
It's as if the clutch is slow to release (just my uneducated guess).
The fluid level is good.
Any ideas?
Any ideas?
Most clutches go farther but I've seen them fail a lot quicker if somebody overloaded the truck or other driving mistakes. I'd suspect clutch disc/pressure plate needs replaced. Good time for clutch release bearing/pilot bearing/slave cylinder if you don't enjoy pulling the trans. It seems I have to go in every so often for rear main seal or something already mentioned. 2wd don't bother me but I hate dropping the 4x4 trans.
1959_f100
03-11-2012 04:38 PM
dominof-250
04-04-2004 12:09 PM
cutlas1972
09-24-2003 06:31 AM
