12v switched power - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
12v switched power
Old 12-21-2002, 09:10 PM
69_bronco 69_bronco is offline
69_bronco is starting off with a positive reputation.
12v switched power
Old 12-23-2002, 01:25 PM
OD OD is offline
OD is starting off with a positive reputation.
12v switched power
I know this has been covered before, but I did not see an answer. I have a 2002 F350 4X4 SRW truck with a service body mounted on it. I want to find a way to get 12 volt power that will go off with the key. I want to install an hourmeter on the console to keep track of running time, and have a way to turn off CB and analog phone when I'm not in the rig.
I found in the fuse panel, #29 fuse is described in the owner's manual as being for "customer accessories". I thought about using a fuse tap, but what does this fuse send power to? Is there a plug or unused wire somewhere in the harness that I can just connect to? A tech at the Ford garage said I should look for a white/light blue wire at the rear of the power panel. I pulled the panel out, and I did not find such a wire; in fact, no unconnected wires at all. Can anyone help? Thanks
Old 12-23-2002, 03:19 PM
FortyFords's Avatar
FortyFords FortyFords is offline
FortyFords is gaining momentum as a positive member of FTE.
12v switched power
Okay ,the Ford tech is correct it is White with light blue.you need to find the diagnostic connector,then follow the wiring harness up from
it towards the bottom of the instrument cluster,supposedly the wire is tied back there.
This is the wire they use for the pto power!
Hope this helps!
:-X12
Rich
02 F250 4x4 SC 5.4v8 6spd 3.73ls Trueblue/Silver and Chrome Nerfs
"All Levers"
Old 12-23-2002, 04:50 PM
OD OD is offline
Post 12v switched power
Thanks, I'll look at it later tonight if I can. Got to work tomorrow, the boss just called. I thought (silly me) that I had the week off. I felt it had to be something simple. I'll post back with results. Thanks again. odie
Old 12-23-2002, 07:41 PM
OD OD is offline
12v switched power
[updated:LAST EDITED ON 23-Dec-02 AT 08:44 PM (EST)] Thanks again. I found the wire where you said it was, and I'm all hooked up to the voltmeter and hourmeter. I think before I hook up the CB and the phone, I'll put in a Bosch relay and use this power source just to pull it in; take power direct from the battery through a fuse for their power. It would take some of the load off that 10 amp fuse!
Thanks also for the FAQ thread, guys. I pulled out my key switch and taped up the contacts for the key-in-the-switch dinger. I like the other things it warns me about, but that drives me nuts with the door open.
I'm new here, but y'all have been a great help to me already. Thanks.
Old 12-23-2002, 08:30 PM
fatdaddy fatdaddy is offline
fatdaddy is starting off with a positive reputation.
12v switched power
That CB or any cb for that matter is going to pull probably less than 5 amps as legally , they can only put out 5 watts of power...on the other hand if that 5 watts is used too Drive a linear amplifier of some significant power level you will definitely need a Fuse.....fd
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 03:27 PM
ooops Aerostar 5 01-14-2015 03:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 06:14 AM
Salvage yards Oklahoma Chapter 14 04-11-2003 10:33 PM
Superchargers walterdanek Ford Inline Six, 200, 250, 4.9L / 300 16 02-16-2001 07:56 PM
Tags
08, 12v, 2008, created, explorer, f150, f250, f350, harness, power, source, superduty, switched, tap, unused, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
