Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-06-2003, 10:37 PM
capridude is starting off with a positive reputation.
2.9 valve adjustment
Hi!
I've run my newly assembled 2.9 for about 20 minutes.
There's a little lifter noise. I just found out that
these hydraulics actually require an initial adjustment,
which is sort of odd.
Anyhoo, the instructions say to get the rockers to neutral
lash (no play, nor binding) and then to "turn in" 1.5 turns.
Doesn't make sense to me! With the lifters bled out, the
valve assembly is supposed to have 1.5 turns TIGHTER?
How can the valves seat, especially after the lifters
pressurize?
Obviously they must mean to "back off" or LOOSEN 1.5 turns?
Any suggestions appreciated!
Cheers, Jeff
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-07-2003, 11:10 AM
pat67shorty's Avatar
pat67shorty is starting off with a positive reputation.
No the lifters ahould already be pumped up. You take all the slack out of the valvetrain, "Zero Lash" but that does not mean you are compressing the plungers all the way down in the lifter. Zero lash is when ther is no longer any slop/up and down movement, but the lifter isnt under load either. Then the 1.5 turns is to preload the hydralic lifter, so than in theory, it is depresed a little, but still has some travel left, but is also has room left to "expand" to take up a growth in the lash of the valve train.
Was that nice and confusing?
__________________
1967 F-100 390/C6/D44-3.54
1985 BroncoII 302/C4/3.45s locked and lifted.
1982 Ford EXP 1.6/4 speed daily driver extrodinare.
  #3 (permalink)
Old 12-07-2003, 11:49 AM
Thank you for your reply!
No, it does make sense-- I had assumed that the hydraulics
bled down quickly, and that I was adjusting when the lifters
were already bottomed out.
I wonder how long they take to bleed down?
(I've always worked with solid lifters!)
Cheers, Jeff
  #4 (permalink)
Old 04-05-2008, 03:37 AM
madclone is starting off with a positive reputation.
Jeff, found your old post. Any update? did you manage to set the lash correctly? 1.5 turn in or out? Old car, old lifters, worn cam etc... It seems that the lifters leak fast enough to make this adjustment senseless.
D
  #5 (permalink)
Old 05-23-2008, 12:37 AM
re: 2.9 valve adjustment
Yes, they should be turned in, or preloaded, 1.5 turns.
Cheers, Jeff
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
