Power Service Diesel Fuel Supplement - Ford Truck Enthusiasts Forums
Old 12-06-2003, 10:25 PM
coglesby coglesby is offline
coglesby is starting off with a positive reputation.
Does anyone use Power Service Diesel Fuel Supplement in their 6.0L? Claims to improve fuel economy by enough to pay for itself. Anyone have experience that validates this claim?
Thanks,
Old 12-07-2003, 10:38 AM
SBV45's Avatar
SBV45 SBV45 is offline
SBV45 is gaining momentum as a positive member of FTE.
I have been using it because it was cheap and available and I couldn't find the Stanadyne. You have to double the mixture to get a cetane increase according to the instructions on the label. I have noticed a slight 1 to 1.5 mpg around town. Does it pay for itself? I haven't done the math. With diesel prices shooting up the way they are, it helps.
I ordered the Stanadyne off the net.
Old 05-16-2008, 01:14 PM
Ron Chichelli's Avatar
Ron Chichelli Ron Chichelli is offline
Ron Chichelli is starting off with a positive reputation.
I have a 1999 7.3 and use the fuel supplement also, it comes in a white bottle.I am not sure what the Diesel Kleen(gray bottle) does different.Is there a difference in what they do?
Old 05-16-2008, 01:21 PM
gtodalep gtodalep is offline
gtodalep is starting off with a positive reputation.
I have an '03 6.0 and lose 1 - 1.5 mpg when i use it. I use the gray bottle, the white is anti-gel for cold weather. I have not tried Stanadyne.
Old 05-16-2008, 02:25 PM
walrus's Avatar
walrus walrus is offline
walrus is gaining momentum as a positive member of FTE.walrus is gaining momentum as a positive member of FTE.
I've used the grey bottle. Mine seems to run a bit quieter, fuel mileage might be a little better, but probably not enough to offset the cost. I run 2x recommeded.
Old 05-19-2008, 11:23 AM
wwb wwb is offline
wwb is starting off with a positive reputation.
If you buy it (either the grey or the white) in the big jug instead of the quart size, the cost per fill is really chump change. Whether it helps mileage or not, they both help cold starting, and both now include a "slick diesel" lubricity additive.
And, if you live up north, the white bottle is really a good thing in the winter.
Old 05-19-2008, 11:30 AM
walrus's Avatar
wwb, you're right. It is much cheaper to buy it by the jug. That's usually how I buy it. I transfer into the small bottles to make it easier to get into the tank.
Old 05-19-2008, 12:56 PM
Beamer 2 Beamer 2 is offline
Beamer 2 is starting off with a positive reputation.
I've used Power Service in my '07 since it was new. Living in up state NY I use the white bottle year round. I mix it 50% greater than the minimum mixture on the bottle. I get 17 to 18 mpg average - 19 to 20 on a trip at 60 to 65 mph. I like the slick diesel lubricity and added cittane for summer and the idea of not freesing up in the winter.
Old 05-20-2008, 08:41 AM
1 Ton Tommy 1 Ton Tommy is offline
1 Ton Tommy is starting off with a positive reputation.
In a conversation with an engineer from Ford about my power issues, Power Service and Stanadyne were mentioned. He thought the cetane boost would help some with my power issues. He cautioned me that these products do not do as much for gelling since ultra low sulfur as they did on the older fuel blends. He recommended using 50/50 no.1/no.2 blend instead of the additive route for winter protection.
Old 05-20-2008, 09:15 AM
brian42's Avatar
brian42 brian42 is offline
brian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to behold
Quote:
the gray bottle is the cetane boost and lubricity enhancer and the white bottle is the cetane boost only for winter blend. I live in So Cal and only use the gray bottle ("winter" is anything less than 60F out here).
I've been using it in mine shortly after getting my rig and I think it helps. Quieter and around 1 mpg better (after the first couple of tanks). Since mine is the 7.3 and my rubber o-rings weren't designed around ULSD, I use it to help mileage and to lubricate all those pesky o-rings.
I use the recommended amount. The bottle says you can't use too much and I'm sure I've built a stockpile of it from the residual left in the tank when I fill it. I buy mine at Wal-Mart for about $16 for a 96oz jug (16oz bottle is around $7). I have a small 16oz bottle that I just pour into and take with me to fill up. You can also get the 16oz bottles at Kragen's (Schuck's/Checker) and Pep Boys (Pep Boys also carries the 96oz jug too).
Old 05-20-2008, 11:26 AM
OZX1's Avatar
OZX1 OZX1 is offline
OZX1 is gaining momentum as a positive member of FTE.OZX1 is gaining momentum as a positive member of FTE.
Brian-
Do you use 8 oz per tank, or 16 oz? I use to use 4 oz, but have started using 8 for the last couple of tanks. I notice better overall mileage and performance with the 2x dose. I wonder what 4x will do?
Old 05-20-2008, 11:53 AM
Blaster7Romeo's Avatar
Blaster7Romeo Blaster7Romeo is offline
Blaster7Romeo is starting off with a positive reputation.
If you are running B-5 do you need to run any for lubricity reasons. or will the 5% bio take care of that?
Old 05-20-2008, 01:35 PM
wwb wwb is offline
Quote:
5% bio is an excellent fuel for lubricity purposes. If you live up north, however, you would do well to avoid the bio in the winter, as it gels very easily, and at substatially higher temps than petroleum diesel. Add the Power Service white in the winter.
Regarding the Power Service stuff..... both white and grey now have a lubricity additive for ULSD. I'm not certain how effective it is, so I'm still adding a lubricity additive. Both the white and the grey have a cetane booster, but the grey gives you a couple more points than the white. The grey also contains an injector cleaner, while the white contains an anti-gel for low temp use.
Old 05-20-2008, 01:42 PM
brian42's Avatar
B-5 will take care of all your lubricity needs.
Quote:
Originally Posted by ozx3+1 View Post
Brian-
Do you use 8 oz per tank, or 16 oz? I use to use 4 oz, but have started using 8 for the last couple of tanks. I notice better overall mileage and performance with the 2x dose. I wonder what 4x will do??
I use about 10 oz. per tank. I did the harpoon mod when I installed my ITP in-tank mod so I am running around 33-35 gallons in my tank when it's full. Since 32oz treats up to 100gal I use 1/3 of that (about 10oz). With the residual fuel still in the tank when I fill it I get a little over the recommended dose. The bottle even says you can't use too much and it boosts the cetane rating. When I first started I poured a whole bottle in each tank for two tanks and then backed off to the standard dose recommended. I definitely noticed an mpg increase when I dump 32oz's in, but dumping in $7 worth of additive into $130 worth of fuel gets pricey, so I get some better performance, economy and lubricity all for about $3 a tank (I get about 9 tanks out of my 96oz jug that cost me $16 at Wal-Mart).
Old 05-20-2008, 01:59 PM
Ok... so would it be worth it to run the gray for the cetane boost and injector cleaner? all the time? normal rate or 2x?
Power service, diesel kleen 97f250 7.3 4x4 1994.5 - 1997 7.3L Power Stroke Diesel 29 03-08-2015 01:45 PM
Power Service Diesel Fuel Supplement? longrange1971 6.7L Power Stroke Diesel 18 01-30-2015 08:22 PM
Diesel Fuel Supplement® +Cetane Boost® Major Marvin 1994.5 - 1997 7.3L Power Stroke Diesel 31 09-04-2011 10:29 PM
Link to the Diesel Supplement Manual? blueheron 6.7L Power Stroke Diesel 1 07-01-2010 10:07 PM
Suppliments(Power Service) Ron Chichelli 1999 - 2003 7.3L Power Stroke Diesel 16 05-17-2008 04:45 PM
Tags
2004, 60, add, diesel, ford, fuel, power, service, slikdiesel, summer, supplement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
