Should my 90 Aerostar have a vacuum line connected to the MAP sensor?
The guy I bought my van from says that the MAP sensor on 1990 Aerostars doesn’t need a vacuum line connected to it, and at this time there is none. Is this right?
If not, how can I find the line that is supposed to be connected to the MAP sensor?
Up until recently, the MAP sensor was a dual-pressure sensor. The MAP side was used by EEC cars that used the speed-density algorithm to determine the mass of the air entering the engine. With the switch over to mass-airflow (MAF) sensors, that was no longer necessary. So the MAP side of the dual sensor is usually plugged up, and its signal is not used.
The other side of the dual sensor is for sensing atmospherric pressure, so it is usually vented to the atmosphere. The EEC still needs this information.
pickncrew
03-17-2008 10:34 PM
DJdemon6696
19
11-22-2007 06:52 PM
