A questions of heads..Help? - Ford Truck Enthusiasts Forums
Old 12-05-2003, 08:13 PM
marcveinotte marcveinotte is offline
marcveinotte is starting off with a positive reputation.
Question A questions of heads..Help?
I found some heads in an old guys garage today...
Aluminum heads off a flat head of some description
Year unknown.. can anyone tell me something about them?
What they fit, are they good? What they are worth?
New in boxes... old guy got them from a local for dealer eons ago... been sitting as spares.
Ford emplem cast into them
number cast into them is #40-6049A2
21 bolt holes in them
Thanks
Marc Veinotte
Old 12-06-2003, 03:46 AM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Marc, the number is for 1933,34 stock heads. Both iron and aluminum were produced. Compression ratio was very similar.
Do you have a pair of heads or two for the same side?
If a pair they should be 40-6049A and 40-6050A.
Can't help you on value, sorry.
Old 12-06-2003, 08:54 AM
Will have to check all 4... I have what I thought was two pairs... will check all casting numbers.
Anymore info would be great and
IF anyone needs these let me know as well.
Marc
MB Guy looking for ford parts help :) marcveinotte Montana Chapter 3 10-29-2004 02:03 AM
STOLEN Set of 4 - 325/85R16 XML'S..... marcveinotte Manitoba / Saskatchewan Chapter 0 08-31-2004 08:34 PM
Clutch info 351M/400 to 352??? marcveinotte FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 6 12-21-2003 02:31 AM
A question on heads for flathead??? marcveinotte 1947 and Older Ford Trucks 1 12-06-2003 02:59 PM
newbie marc9000 New Member Introductions 6 12-01-2003 11:33 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
