6.0L Maintenance Schedule from Ford-Generic Schedule
Good info for those who need it......hard to read but worth it...
General Maintenance Information — 6.0L Diesel Engine
The Normal Schedule applies to operation of the vehicle under typical, everyday driving conditions. The maintenance frequency in this schedule typifies what the vast majority of vehicles will require. The listed services should be carried out at specified mileage intervals. There are, however, additional services that only the noted vehicles require.
If the vehicle is operated in one or more of the following Special Operating Conditions, those additional services will be required. The Special Operating Conditions are:
towing or carrying heavy loads.
extensive idling and/or driving at low speeds for long distances.
driving in dusty conditions.
off-road operation.
short trip, cold operating conditions.
There are also exceptions to the Normal Operating Schedule which will require more frequent maintenance for some components. Those exceptions are:
normal vehicle axle — maintenance and lubrication.
police and taxi vehicles — maintenance and lubrication.
engine oil and yellow coolant — time and mileage-based interval.
Special Operating Condition Requirements
When towing a trailer or using a camper or car-top carrier:
Change engine oil and install a new oil filter every 8,000 km (5,000 miles) or 6 months.
Change automatic transmission fluid and lubricate 4x4 front hub needle bearings (F-Super Duty) every 48,000 km (30,000 miles).
Change transfer case fluid every 96,000 km (60,000 miles).
Change manual transmission fluid as required.
Inspect and lubricate U-joints as required.
During extensive idling and/or low speed driving for long distances, as in heavy commercial use such as delivery, taxi, patrol car or livery:
Change engine oil and install a new oil filter, lube front lower control arm and steering linkage ball joints with zerk fittings (if equipped) every 8,000 km (5,000 miles) or 6 months.
Inspect brake system and check electrolyte level (ambulances) every 8,000 km (5,000 miles).
Install a new fuel filter every 24,000 km (15,000 miles).
Lubricate 4x2 wheel bearings, install new grease seals and adjust bearings every 48,000 km (30,000 miles).
Install new spark plugs and change transfer case fluid every 96,000 km (60,000 miles).
Install a new cabin air filter as required.
When operating in dusty conditions such as unpaved or dusty roads:
Change rear axle lubricant (F-450 and F-550 only) every 80,000 km (50,000 miles).
Install a new engine air filter as required.
When operating in off-road conditions:
Lubricate 4x4 front hub needle bearings (F-Super Duty) 24,000 km (15,000 miles).
Change automatic transmission fluid every 48,000 km (30,000 miles).
Inspect and lubricate U-joints.
Inspect and lubricate steering linkage ball joints with zerk fittings.
If vehicle is frequently driven on short trips in cold operating conditions:
Change engine oil every 8,000 km (5,000 miles).
Checks and Services
Certain basic maintenance checks and inspections should be carried out at specified intervals. Any recognized adverse condition should be corrected as soon as possible.
Maximum Oil Change Interval (Normal Schedule)
12,000 km (7,500 miles) or 6 months, whichever occurs first.
Maximum Oil Change Interval (Special Operating Conditions)
8,000 km (5,000 miles) or 6 months, whichever occurs first.
Monthly Checks
Check each of the following items every month:
All interior and exterior lights
Tires for wear and correct air pressure
Engine oil fluid level
Windshield washer solvent fluid level
Check and drain fuel/water separator
Six Month Checks
Check each of the following items at least every six months:
Lap/shoulder belts and seat latches for wear and function
Spare tire air pressure
Power steering fluid level
Parking brake for correct operation.
Safety warning lamps (brake, ABS, air bag, safety belt) for correct operation
Coolant system fluid level and correct strength
Battery connections. Clean if necessary.
Clutch fluid level, if equipped
Check windshield washer spray, wiper operation and clean all wiper blades.
Lubricate all hinges, latches and outside locks. Inspect for correct operation.
Lubricate door rubber weatherstrips. Inspect for excessive wear.
Clean body and door drain holes. Inspect for clogs and obstructions
off-road operation.
Checks and Services
Monthly Checks
Six Month Checks
Normal maintenance schedule:
Normal Schedule
The following checks or procedures should be carried out for vehicles with 6.0L diesel engines only.
12,000 Km (7,500 Miles)
Change engine oil and install a new oil filter.
Rotate tires and inspect for wear.
Inspect engine air filter.
24,000 Km (15,000 Miles)
If equipped, install a new cabin air filter.
Install new frame-mounted and engine fuel filters.
Inspect and lubricate steering linkage, suspension and, if equipped, driveshaft and ball joints.
Inspect wheels for end play and noise.
Inspect engine cooling system and hoses.
Inspect brake pads, shoes, brake discs, drums, brake lines and hoses.
Inspect exhaust system and heat shields.
36,000 Km (22,500 Miles)
48,000 Km (30,000 Miles)
Install a new engine air filter.
If equipped, change automatic transmission fluid and install a new external filter.
60,000 Km (37,500 Miles)
Inspect tires for wear. Rotation recommended for optimal tire life.
72,000 Km (45,000 Miles)
84,000 Km (52,500 Miles)
96,000 Km (60,000 Miles)
Lubricate 4x2 wheel bearings or 4x4 hub needle bearings and install new wheel bearing grease seals.
If equipped, change automatic transmission fluid and external filter.
If equipped, change manual transmission fluid.
108,000 Km (67,500 Miles)
120,000 Km (75,000 Miles)
Change engine coolant.
132,000 Km (82,500 Miles)
144,000 Km (90,000 Miles)
156,000 Km (97,500 Miles)
Inspect accessory drive belt.
Change rear wheel drive axle fluid (DANA axles using non-synthetic lubricants ONLY).
168,000 Km (105,000 Miles)
180,000 Km (112,500 Miles)
192,000 Km (120,000 Miles)
Lubricate 4x2 wheel bearings or 4x4 hub needle bearings.
Install new wheel bearing grease seals.
204,000 Km (127,500 Miles)
216,000 Km (135,000 Miles)
228,000 Km (142,500 Miles)
240,000 Km (150,000 Miles)
Install a new accessory drive belt.
If equipped, lubricate 4x4 hub needle bearings.
If equipped with loose bearings, install new 4x2 wheel bearings and install new wheel bearing grease seals.
Normal Schedule
Severe Maintenance Schedule Part 1:
Special Operating Conditions (Severe Duty) Schedule
The following checks or procedures should be carried out for vehicles with 6.0L diesel engines only that operate under Special Operating Conditions (Severe Duty).
8,000 Km (5,000 Miles)
Inspect brake pads, shoes, brake discs, drums, brake lines and hoses (under commercial use conditions, as required).
If equipped, inspect and lubricate 4x2 ball joints and steering idler arms (under off-road or commercial use conditions, as required).
16,000 Km (10,000 Miles)
Inspect brake pads, shoes, brake discs, drums, brake lines and hoses (under commercial use conditions as required).
If equipped, inspect and lubricate 4x2 ball joints and steering idler arms (under off-road or commercial use conditions as required).
Inspect steering linkage, suspension and, if equipped, driveshaft and ball joints.
If equipped, inspect and lubricate 4x2 ball joints and steering idler arms.
If equipped, lubricate 4x4 hub needle bearings (under off-road conditions, as required).
32,000 Km (20,000 Miles)
40,000 Km (25,000 Miles)
Lubricate 4x2 wheel bearings or 4x4 hub needle bearings (under trailer towing or off-road conditions, as required).
Install new wheel bearing grease seals (under commercial use, as required).
56,000 Km (35,000 Miles)
64,000 Km (40,000 Miles)
80,000 Km (50,000 Miles)
88,000 Km (55,000 Miles)
92,000 Km (60,000 Miles)
If equipped, change transfer case fluid.
If equipped, lubricate 4x2 wheel bearings or 4x4 hub needle bearings (under trailer towing or off-road conditions, as required).
100,000 Km (65,000 Miles)
108,000 Km (70,000 Miles)
116,000 Km (75,000 Miles)
124,000 Km (80,000 Miles)
132,000 Km (85,000 Miles)
Severe Maintenance Schedule Part 2:
140,000 Km (90,000 Miles)
148,000 Km (95,000 Miles)
Inspect brake pads, shoes, brake discs, drums, brake lines and hoses (under commercial use, as required).
156,000 Km (100,000 Miles)
164,000 Km (105,000 Miles)
If equipped, lubricate 4x4 wheel bearings or hub needle bearings (under off-road conditions, as required).
172,000 Km (110,000 Miles)
180,000 Km (115,000 Miles)
188,000 Km (120,000 Miles)
196,000 Km (125,000 Miles)
204,000 Km (130,000 Miles)
212,000 Km (135,000 Miles)
220,000 Km (140,000 Miles)
228,000 Km (145,000 Miles)
236,000 Km (150,000 Miles)
If equipped, lubricate 4x4 hub needle bearings (under trailer towing or off-road conditions, as required).
If equipped, install new 4x2 wheel bearings.
