how to tell if alternator is bad? - Ford Truck Enthusiasts Forums
Old 12-03-2003, 12:48 AM
97flairside 97flairside is offline
97flairside is starting off with a positive reputation.
What are some signs other then dimming lights that a alternator is going bad? Tonight everything seemed fine with my truck untill i went to start it after leaving barnes and noble. I put the key in and tured, heard a pop then eveyrthing went dead. Nothing worked at all. Called triple A they came and gave me a jump start. It worked but i couldn't believe i needed it. Its a brand new battery purchased in september.
What else could've caused what seemed like a short?
Old 12-03-2003, 01:47 AM
punchy1's Avatar
punchy1 punchy1 is offline
punchy1 is starting off with a positive reputation.
how did it act after it was jumped? if it acted kinda' funny, like it had lost power or maybe the radio or something was dim or faint, it probably is your alt. i've been going through some charging problems my self the last few days. there are ways to check it, but most auto part stores will do it for 'ya free.
Old 12-03-2003, 04:16 AM
Mike W's Avatar
Mike W Mike W is offline
Mike W is starting off with a positive reputation.
You might have blown a fuse link. I don't believe an alternator would make a pop, plus you lost all power.
Old 12-03-2003, 10:56 AM
78fordman's Avatar
78fordman 78fordman is offline
78fordman has a good reputation on FTE.78fordman has a good reputation on FTE.78fordman has a good reputation on FTE.
Usually is what i do, is take off the battery terminals and see if it is still running, if it dies, it is not charging. Just just it is not charging, does not mean the alternator is bad, could be the regulator, or the wiring. If it keeps running, for the moment it is fine. Something might be grounding out, and you hearn a loose wire connectoin weld its self to something.
Old 12-03-2003, 02:43 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Quote:
I do not recommend taking the battery cable off with the engine running. You can blow up stuff in a hurry. I learned this the hard way. Pulled the cable off a pickup I had onetime, it ran for about 10 more seconds and then quit. Would crank but not start after that. Know what I did? I blew the ignition module. Lesson learned.
As far as the original problem, I would try the easy stuff first. I would take the battery terminals loose and clean them.
Old 12-03-2003, 04:36 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Removing a Battery cable from a vehicle While the engine is running will blow diodes & destroy your alternator.
Tye voltage regulator is what determines the voltage flow not the alternator.
That's why the headlights dim at idle, the engine has to reach at least 800 rpm to have the VR kick in and provide extra power.
Removing the battery cable:
You guys are behind some 40 years as this practice was used on [size-4] Generator type vehicles[/size]
It was done to SPIKE the system to get the generator/voltage regulator to work.
Old 12-03-2003, 10:24 PM
when it got jumped the idle was off, not normal at all. If i turned the wheel to much the engine would die, if i came to an abrupt stop it would die or just stop at a light it would dip down to almost 100rpms then go up to 700rpms then even out at 400rpms.
It did this today today but not nearly as bad. The lights would dim as the rpms dropped.
Whatever did happen it feels like I have another engine in my truck. It feels like there is more power.
What could've caused this problem? I mean it ran fine before i went into barnes and noble. When I put the key in it lit the dash up like normal but as soon as you go to START everything went dead. I don't get it.
Old 12-03-2003, 10:50 PM
Clean all the connections & grounds at the starter solenoid, V/R,Battery
Renegadesrun Renegadesrun is offline
Renegadesrun is starting off with a positive reputation.
Drop by autozone (and about 10 other chains) and let some kid check it for free.
Old 12-03-2003, 10:55 PM
not to sound stupid but what would cleaing the connections on the starter have to do with anything? It's not like it wanted to crank there were no lights on the dash nothing lit up, no noises at all. Where is the V/R located? Battery terminals are clean as can be.
Old 12-03-2003, 11:26 PM
punchy1's Avatar
while the truck is off, try the lights. if lights are dim or dead, then it isn't starter connections. i have a feeling it probably is you're altenator. the only weird thing is that popping sound. try and see if batt. takes charge with external charger. or if you have a voltmeter in truck or a handheld multimeter, then jump off truck and check if voltage raises, if so then your alt. is good.
Old 12-04-2003, 12:09 AM
I never said starter, I said the starter solenoid,plus all the cables & mounting areas.
Everything connects to the Voltage Regulator(V/R)
For Peace of Mind
You want to MAKE sure that everything is CLEAN ,TIGHT & making good contact before trying to trouble-shoot the system.
That includes the Mounting area of the V/R & starter solenoid.
Old 12-04-2003, 12:42 AM
where are all these things located? the poping sound i heard wasn't to loud. Maybe it was just everything just shutting off that made a noise.
Old 01-02-2004, 01:54 AM
archangel archangel is offline
archangel is starting off with a positive reputation.
It was that small piece of lead that was still in contact with the battery burning away at the battery/cable connection as the rest of the battery clamp was insulated by corrosion and or crud!
The man said it more than once, and he was right, "so pretty please, with sugar on top, clean the friggen connections!"
In part (the last two lines) shamelessly stolen from Pulp fiction!
Old 01-02-2004, 06:48 PM
well i took some thin pieces of lead and hammered them flat and put them on the terminals. It helped alot. Terminals weren't dirty. The negative bolt was tightened all the way but it slid off easily.
2006 Navigator / 2006 F150 intermittent check charging system light Robber80 1997-2006 Expedition & Navigator 7 09-25-2014 06:13 PM
F-350 Alternator Problem? KirstenxMarie 1999 to 2016 Super Duty 14 08-03-2013 07:56 PM
2003 F-250 alternator problems craigt8 1997 - 2003 F150 2 09-05-2011 02:24 AM
2003 F250 alternator problems craigt8 1999 to 2016 Super Duty 5 09-04-2011 04:04 PM
Alternator issues-HELP! DK Farms 6.0L Power Stroke Diesel 13 03-02-2010 11:41 PM
Tags
alt, altenator, alternator, bad, battery, charging, dead, die, ford, hw, lights, pop, regulator, sound, voltage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
