Rear spring block / fog lights
>Thanks Nomo, perfect explanation!
>Matt
I get it !! but I'm all foggy now though !
':-X23')
':-X23')
Nomo and Weldman stop it!
And Monsta don't you even think about any comments!
later guys
Rich
Ford Trucks Built Tough!
not with rocks
Watch out "X" Mayor of Truckville
>Matt
':-X23')
':-X23')
later guys
Rich
not with rocks
i am having a terrible time getting my face off of the switch. im getting highly frusterated!!! not to mention i already broke some of the plastic that releases the plug ins. maybe ill just leave it alone fer the night b/f i have to buy a new switch.
-nathan
-nathan
[updated:LAST EDITED ON 03-Apr-02 AT 11:34 PM (EST)]redranger,
If you have a truck that allows you to turn on the fogs with the parking lamps, you don't need to do anything to the switch. If you have a truck that doesn't have this feature, you need to heat up those plastic things with a solder iron or hot nail.
Then heat them up again to put the switch back together.
I just read that you have an '02, you shouldn't have to take the switch apart!!!!!!!!!!!
good luck!
good luck!
I believe that the wire colours for '02 that your have to splice are:
red/black and brown.
I've also heard that you cap off the red/black wire going to the switch. I don't THINK that you have to cap off the brown wire. (meaning that it still goes to the switch as well as the red/black)
Hope thats clear as mud!
#28
[updated:LAST EDITED ON 04-Apr-02 AT 01:30 PM (EST)]my truck was made in nov so i must have an old switch in my truck. it does not pull out in the parking lights position. also, what do you mean you hace to "cap-off" the red/black wire? i dont think i have one. just a black/white one.
-nathan
-nathan
#29
I've heard that its the white/black wire that you are referring to on the '01's (and early '02 I guess).
Also, from my travels to ford-diesel, I think that you have to cap off the red/black on the 02's, meaning that you terminate it at the back of the plug.
I don't THINK that you have to do that on the '01 style.
But if you get wierd operation like not being able to turn your fogs off or only work when the headlights are on, terminate that wire. I'm a little foggy on this because I was only paying attention to the info pertaining to my truck. which leads me to ->
**I'm not responsible if your truck burns, I am simply trying to give you what I read at ford-diesel**
Did that help?
Matt
Did that help?
Matt
#30
