key wont turn... - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
key wont turn...
Old 12-02-2003, 06:19 PM
johnclements johnclements is offline
johnclements is starting off with a positive reputation.
key wont turn...
i have a 2wd nothing special about it ranger and when i stick the key in it just wont turn. I can take the key out and stick it back in and it just wont turn. The wheel is locked but I dont know if that has anything to do with it... any help would be appreciated.
Old 12-02-2003, 06:28 PM
hreed hreed is offline
hreed is starting off with a positive reputation.
Sometimes the wheel being locked put pressure on the lock making it difficult to turn. Try wiggling the steering wheel while you try turning the lock. If that doesn't work, try pulling the key out and turning it over. Sometimes the key is not exactly cut on both sides. Only one side of the key actually sets the tumblers in the lock. If neither of these work (assuming you are not using the wrong key for that vehicle), you may have something broken or lodged in the lock. You also might try some graphite key lube in the lock. Don't use oil! Good luck.
johare's Avatar
johare johare is offline
johare is starting off with a positive reputation.
This might be obvious and you may have tried it but here goes. Try rocking the steering wheel back and forth while trying to turn the key. Sometimes the tumblers in the steering wheel lock get worn and rocking it may allow you to turn the key.
Old 12-02-2003, 06:30 PM
Richard4447 Richard4447 is offline
Richard4447 is starting off with a positive reputation.
Jiggle the steering wheel while strying to start/turn the key. I know on some vehicle if the wheel is turned sharp that the wheel locks and makes the key difficult to turn. Play with the wheel that it is in between stop clockwise and counter clockwise.
Also make sure the tranny is in park and not stuck on the ledge before the shifter drops into the park position.
Just a thought.
Old 12-02-2003, 06:38 PM
pmorris710 pmorris710 is offline
pmorris710 is starting off with a positive reputation.
You don't say how old it is, but on my 93 it did that, the switch was jiggly, and it wouldn't turn sometimes, a new ignition switch is available for probably under 15 bucks at the parts store, fairly easy to install if you have the repair book, you'll have seperate keys for the ignition and doors
Old 12-02-2003, 06:55 PM
BlueOvalAngel BlueOvalAngel is offline
BlueOvalAngel is starting off with a positive reputation.
i have the opposite problem!
with my truck (and the 91 f-150 my dad had) you can pull the key out of the ignition with the engine running! i don't know why it does that, anybody have any ideas?
i like it like that, tho, i can stop at the wawa (a 7-11 like store) and leave my truck running and locked, so it stays nice inside it while i run inside. expect for that one time i left it running and locked the key inside in the ignition...
Old 12-02-2003, 07:24 PM
johare's Avatar
BlueOvalAngel,
Most likely your ignition switch tumblers are so worn that you can remove the key without interrupting the ignition system. You could replace the ignition switch if you want to correct it.
Old 12-02-2003, 10:05 PM
kevinswart kevinswart is offline
kevinswart is starting off with a positive reputation.
BlueOvalAngel,
Most of the 80's Frod ignitions are like that. I remember my Dad bought a brand new 1980 F250 and within 6 months it was like that. My 87 does it but I agree this is a feature not a problem.
Kevin
Old 12-02-2003, 10:38 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile CowboyBilly9Mile is offline
CowboyBilly9Mile is a name known to allCowboyBilly9Mile is a name known to allCowboyBilly9Mile is a name known to allCowboyBilly9Mile is a name known to allCowboyBilly9Mile is a name known to allCowboyBilly9Mile is a name known to all
In addition to everything else mentioned, with the key in the ignition, wiggle the ignition switch vigorously while trying to start it. If something like lock ease does not remedy the problem, replace the switch ASAP to avoid having it stay in the crank mode sometime down the road
truck broke into/cant turn Key! walleyeca 1999 to 2016 Super Duty 11 03-15-2010 09:59 AM
starter question powerman6.0L Electrical Systems/Wiring 8 02-08-2007 11:41 AM
Key sticks in the ignition? goldielox 2004 - 2008 F150 8 12-23-2005 09:57 PM
My Key wont turn off my 1996 F150 i just got. timmyjoe 1987 - 1996 F150 & Larger F-Series Trucks 2 07-16-2005 08:43 PM
Key wont turn in ignition in 1999 nyunicorn 1997-2006 Expedition & Navigator 3 12-15-2003 07:40 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
