1993 Ranger Manual Transmission Fluid Leak - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 12-02-2003, 10:53 AM
budman2003 budman2003 is offline
budman2003 is starting off with a positive reputation.
I have a 1993 3.0L V6 5spd manual Ranger and i have been noticing a slight transmission fluid leak. I am not mechanically inclined at all so I am curious as to what the problem could be and if it should be attended to quickly? Any input on this matter would be greatly appreciated.
Thank you
Old 12-02-2003, 01:15 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
Welcome to FTE!!!!
There are plugs on the top of the tranny that leak and you should fix it. Check out the link in the tech info post.
Old 12-02-2003, 02:01 PM
Thanks for the quick response Ken. The link for the shift-rail plugs looks like a great place to start.
Old 01-13-2004, 06:12 AM
Andywk's Avatar
Andywk Andywk is offline
Andywk is starting off with a positive reputation.
Could these also be the cause of some fluid that seems to be coming inside the cab of a truck by the base of the shifter or would this be another problem altogether?
Old 01-13-2004, 01:33 PM
el conquistador el conquistador is offline
el conquistador is starting off with a positive reputation.
that sounds like an entirely different problem
Old 01-14-2004, 11:10 PM
Hank85713 Hank85713 is offline
Hank85713 is gaining momentum as a positive member of FTE.
if its comming into the cab, then yes Id bet on the upper plugs. Get a mirror and look up there to verify. you can pull the shifter and its associated rubber covers off. If it just started you might be ok. get the fluid level checked ASAP. I bought my truck, someone had let the plugs leak, plugged them with RTV and it burned up the mainshaft and 1st gear. Thjats probably why they sold it. Anyhow $900 for a rebuild, new clutch kit, slave and master cyl's I had the plastic plugs replaced with the steel ones. Bad point is you have to pull the trans to get this fix.
1993 F250 Manual Transmission ebuck31 1987 - 1996 F150 & Larger F-Series Trucks 8 05-08-2015 04:48 PM
93 a4ld transmission fluid not circulating yumanite Ranger & B-Series 4 05-08-2012 09:36 AM
Brake fluid leaking! seagullplayer Ranger & B-Series 11 09-28-2011 01:24 AM
OBS manual transmission crossmember 99ranger4x4 WTB - Parts & other 6 08-15-2011 12:03 AM
Manual Trans with leaking plugs jimw411 Ranger & B-Series 8 12-20-2005 06:23 PM
Tags
1993, 93, f250, fluid, fluids, ford, leak, leakiing, leaking, manual, manuel, maual, plugs, ranger, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
