Ford f250 STRIPPED OIL PLUG CANT REMOVE HELLLLP
Oil drain plug
I have owned Ford trucks for 23 years and I have had that problem more than onece. Is the oil pan in good shape? My 89 F150 300 six 4x4 oil pan went last fall. Now as far as the oil plug go,es try backing off with preshire . Then then talk to somebody about an oversize plug for that I have used it for years and no problem your are better off to have a mech. work on it for you so if it fails you can blame him. Good luck and do not worry because it is a common problem.
Oil plug
Well get it fixed fast I have seen them start to leak more & more as time went on. Good luck let me know how it works out.
88 F250 2wd 300 six 5spd pickup
99 F250 2wd 5.4 auto 8ft rack body dump 4.10
00 F350 4wd power stroke 6spd 9ft rack body 4.10
04 F250 4wd 5.4 6 spd pickup 3.73
well after i wrote last i went out and pulled that sucker out with some vicegrips no prob...will let drain and tommorrow i will be putting the new oversized plug in..keep ya posted.............
QUESTION?
i have a rod knocking,if i use 20w40 oil will that help quiet that knock since it is thicker?I am saving up the 2300$ to get a new engine but in the meantime will that work or what do u think?
QUESTION?
it is a v8 5.8 with 154000 milesi dont usually drive over 40 just to get to and from work right now....its such a perty truck i cant junk it i bought it for 800$ with a brand new edelbrock carb 4bbl new sensors new computer brain new starter 33' all terrains goodrich lots of tread a dana 60 the body is in awesome condition could use a little tlc around the tirewalls but as far as rust and scratches dents go NONE and the interior is in perty good shape so i think its worth the $ to fix it up.its a 1987 ford xlt lariat 3/4 quarter ton with 154k miles
Drain
If I where you I would think about a used low mileage motor sounds like that one is getting tired. I only got a 140,000 miles on my 5.8 motors but I work the snot out of then with my work. You can find low mileage motors that came out of wrecks cheap Give that some thought if you did that you will save more money than rebuilding this one.
Oil Pan
Some salvage wards will let you hear the motor 1st before you buy. It go like this buyer beware. I am sure you can find something good ware you live. Ask around I bet you can find a great motor for around a $1000.00 or less check it it wont cost anything to check into it. Good Luck
ronnjonn
10-23-2006 08:01 PM
roaringsaleen
10-29-2005 10:52 AM
amckeag65
08-20-2002 08:29 PM
