Hello. welcome to FTE!
Yes, the oil pressure gauge that you have is more or less a dummy guage. Once a certain pressure is attained the gauge registers and reads in the middle somewhere. It's only an indication that the pressure has reached a certain level, so it does not really measure anything. When the oil pressure is below that threshold (forgot what it is), then your oil gauge may be reading zero, even though there is pressure.
Now that it's colder out it's probably taking a little longer for the oil pressure in your motor to attain the appropriate level in order register on the guage. So one thing to think about is oil viscosity ...what weight oil are you running? During the colder weather here in CT I use nothing more than a 5 winter weight (for example, 5W-30).
__________________
'98 Ranger XLT 4x4 (4.0L)
'97 Taurus GL (3.0L Vulcan)
'94 Taurus SHO (MTX)
Ford Pics
