how to replace alternator in 98 F150 4.6 ??? - Ford Truck Enthusiasts Forums
Old 12-01-2003, 11:21 AM
switchback switchback is offline
switchback is starting off with a positive reputation.
Question how to replace alternator in 98 F150 4.6 ???
Hello, are there any online manuals on the internet that could assist me in replacing my alternator? The bearings went out and I'm not sure how to remove old alternator out of truck. Thanks in advance!!!
Old 12-01-2003, 11:11 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Disconnect the negative battery cable.
Rotate the drive belt tensioner away from the drive belt and remove the drive belt from the alternator pulley.
Detach the electrical harness connectors at the alternator assembly.
Disconnect the positive battery cable and remove the nut and washer.
Remove 2 front alternator bolts.
Remove the rear alternator support bracket retaining bolts and the support bracket.
Remove the alternator from the vehicle.
To install:
Place the alternator in position and loosely install 2 front alternator retaining bolts.
Install the alternator bracket and 3 alternator bracket bolts. Tighten to 84 inch lbs. (10 Nm).
Tighten 2 front alternator retaining bolts to 19 ft. lbs. (26 Nm).
Connect 2 electrical harness connectors to the alternator assembly.
Connect the positive battery cable and install the nut and washer. Tighten the nut to 72 inch lbs. (8 Nm).
Rotate the drive belt tensioner away from the drive belt and install the drive belt on the alternator pulley.
Connect the negative battery cable.
Start the engine and check for proper charging system operation.
Replacing Alternator Bracket/Mount Trojan8975 1987 - 1996 F150 & Larger F-Series Trucks 0 03-28-2012 09:09 PM
smoking alternator brutusman 1987 - 1996 F150 & Larger F-Series Trucks 9 03-07-2011 04:48 PM
Alternator replacement/ How to Reid lariat 2004 - 2008 F150 6 09-21-2010 05:57 PM
weak batts or alternator bad?? Slopitch 1999 - 2003 7.3L Power Stroke Diesel 4 01-08-2008 04:29 PM
How to check if alternator works...? Muddweiser 1978 - 1996 Big Bronco 19 07-28-2004 08:37 PM
Tags
150, 1989, 2006, 46, 98, altenator, alternator, change, expedition, f150, ford, remove, replace, replacement, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
