How much oil
Old 12-01-2003, 04:22 AM
Will Woodfine's Avatar
Will Woodfine
Will Woodfine is offline
How much oil
How much oil does it take to fill your trucks engine, mine takes about 7 liters, thats just over 7 quarts, is that stock, my Haynes manual says I should only be using 5 liters. I also have an engine oil cooler on the truck it was there when I bought it. Is that stock for an F150, I am from Canada and so is the truck anybody's opinion would be great
Old 12-01-2003, 04:23 AM
Will Woodfine
Oh yea my truck is an 1997 model
Old 12-01-2003, 05:44 AM
AjRagno's Avatar
AjRagno
AjRagno is offline
7 should be okay with the oil cooler.
-6 qts with a filter change is acceptable
-6 1/2 qts with filter is full
-7 qts with filter is max according to Ford spec book
Old 12-01-2003, 06:24 AM
Will Woodfine
Thanks for the info AjRango
Old 12-01-2003, 12:02 PM
Busa01's Avatar
Busa01
Busa01 is offline
2003, my manual says 6 quart capacity. hmm.
Old 12-01-2003, 12:09 PM
Jimmy Dean's Avatar
Jimmy Dean
Jimmy Dean is offline
Geez I use between 5 and 6 normally.
Old 12-01-2003, 02:21 PM
Will Woodfine
does anybody know if the oil cooler is stock or if it was an add on maybe thats the reason I use more oil in my truck,
Old 12-01-2003, 02:23 PM
Jimmy Dean's Avatar
Jimmy Dean
honestly no idea.
Old 12-01-2003, 02:24 PM
true4.2's Avatar
true4.2
true4.2 is offline
I just changed my oil 2 days ago. I used 6 1/2 quarts which filled it perfectly.
Old 12-01-2003, 02:45 PM
Busa01's Avatar
Busa01
Busa01 is offline
Oil cooler? Do you have an auto trans? Are you sure it's not a tranny cooler. You mean the small radiator mounted in front of your large radiator? That's your tranny cooler.
Old 12-01-2003, 03:19 PM
Will Woodfine
No my truck is a five speed manual, its got a cooler infront of the rad could it be for the A/C? from the threads so far I dont use too much more oil than anybody else.
Will
Old 12-01-2003, 03:35 PM
Busa01's Avatar
Busa01
Busa01 is offline
It's a tranny cooler......i'm 99.9999999999% sure it is.
(i have to leave a little room for error you know : )
Tom
Old 12-01-2003, 03:41 PM
Will Woodfine
It's cant be for the tranny, unless, ford started putting tranny coolers, on manual trannies, aswell as autos.
Will
Old 12-01-2003, 03:43 PM
Busa01's Avatar
Busa01
Busa01 is offline
Well, one way to find out, crawl underneath and look, or call the Dealer. I'm pretty certain they don't put oil coolers on cars. Motorcycles yes, but cars no. I'm pretty certain it's a tranny cooler, auto or manual, when your towing that fluid can still get hot.
Old 12-01-2003, 03:51 PM
Will Woodfine
I will do that I get back home next sunday, I'm away on Vacation visting friends in Brussels.
Quick Reply: How much oil
