1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Child proof Locks
Old 06-22-2004, 02:18 AM
pounder90's Avatar
pounder90
pounder90 is offline
Same problem, '00. Good catch Freek.
Old 01-22-2005, 12:44 PM
windyhill's Avatar
windyhill
windyhill is offline
THANKS!!! Just what needed! I've been ****ed at my four boy for three years now,blaming them for putting on the child lock... Man I feal like a real smuck. Although It is just like something they would do. And "Dads always right" in my house....Oh well they don't need to know!
Old 11-05-2005, 08:43 PM
rmharvey's Avatar
rmharvey
rmharvey is offline
mee too
97 expedition xlt left rear
Old 11-06-2005, 03:58 PM
russ1416807's Avatar
russ1416807
russ1416807 is offline
add my 00' to the list as well...thanks 4 the info freek...a BIG thanks from my kids as well
Old 11-06-2005, 04:15 PM
EagleDakota's Avatar
EagleDakota
EagleDakota is offline
And I thought my 00 was haunted. Really appreciate this post.
Old 11-07-2005, 06:48 PM
quick35th's Avatar
quick35th
quick35th is offline
The passenger rear door does this in my '99 EB expy.
Shane
Old 11-07-2005, 09:11 PM
TX76F250's Avatar
TX76F250
TX76F250 is offline
Add my '99 to the list! This is a perfect example of the good that can come from FTE!!! We thought that my girls were somehow knocking it back to lock. I'm gunna knock this one out tomorrow! Thanks!
Old 11-18-2005, 07:32 AM
cmachk's Avatar
cmachk
cmachk is offline
yep
Same thing with my 98 right rear passenger door locks right up everytime! Thanks!
Old 12-14-2005, 11:11 AM
Notpilbrisk's Avatar
Notpilbrisk
Notpilbrisk is offline
me i hate that god da*mn door thanks for the help
Old 12-14-2005, 11:56 AM
Billabong's Avatar
Billabong
Billabong is offline
Thanks!
Your solution is much better than my own (remove rear doors). Especially with colder weather upon us.
Old 07-24-2012, 11:27 AM
David Yarborough's Avatar
David Yarborough
David Yarborough is offline
Permanent FIX
SOLUTION!!! I put up with this for years with my 2001 Lincoln Navigator.
The hardest part to fixing it is removing the interior door panel, so make sure you find out how to do that on your model before you destroy some expensive plastic parts. Once that is off, the rest is a piece of cake.
The problem is caused by the interior door handle rod. It needs to be adjusted because it is too short, allowing the door handle to open too far. A plastic clip attaches the door handle to the rod (the rod that connects the interior door handle to the door latch). Unhook the the clip and lengthen the rod by moving it back towards the latch, then close the clip to reattach the rod. The door handle will not pull open quite as far. Test the adjustment by switching the child lock to the unlock position, and while leaving the door open, pull the interior door handle open and closed rapidly several times. If the child lock switch no longer "climbs" from the unlocked to the locked position, shut the door and make sure it will still open when you pull the interior door handle. If so, you fixed it! If not readjust the rod and try again. Good luck.
Old 12-04-2012, 01:08 PM
ldou's Avatar
ldou
ldou is offline
My 98 Nav also thank you can't wait to get home and fix
  #28
Old 12-04-2012, 10:48 PM
etewald's Avatar
etewald
etewald is offline
I just used a short self-tapping screw and screwed it in just under the button when it was in the unlock position. It stops the button from moving.
e23barton
2017+ Super Duty
07-28-2017 06:11 AM
Hkyplayr2
01-08-2017 06:06 AM
Lancester
10-07-2015 07:43 PM
Redneckfordf2502002
06-03-2013 10:05 AM
DSMMH
03-08-2010 11:01 AM
Quick Reply: Child proof Locks
