(follow up on previous posts) ok i have decided what to use on my 351w (heads,manifold,carb,cam,ect.) and now i was wanting suggestions on what brand or type of pistons and rings and berrings and i want the best i can get. and im not sure but i think im not going to bore it over at all soo and suggetstions
I would go with cleveite bearings, i would get pistons with a comp ratio of about 11:1. Compresion will raise the horsepower and torque level, all accross the board.
the reason i wasnt sure if i was going to bore out or not is because i didnt know if i was going to use the block i had and bore it or just get one that is already clean and good and stuff but i decided to go and spend a little for a new one
The summit kit is used by many people with good results, it contains all quality parts. Yeah if you have a fresh block then I can understand why an overbore isn't needed, I thought it odd that someone chose not to overbore a block, not too many folks buy new block. Where did you find the fresh block and did you get a good deal?
The pistons you choose depand on wheather or not your going to be blown or nitrous or NA? Forged is best, JE are good pistons...but I would not try to make my HP with high compression, with 11 to 1 for a street motor, your just looking for detonation problems.
