How many miles do you guys have on your trucks ?
#1366
I only use Rotella T, in all my trucks, plus 1 qt of trans fluid in the crankcase. It's an old habit thats never been proven to help or hurt anything. It's changed every 5,000 miles, along with the fuel filter. I change the air filter every 10 to 15 k, depending on where i'm running. Every year I drain the cooling systems and flush them then make sure the additives are the right amounts I use the Ford recommended coolent. The only synthetic I use is in my rearend differential, since I run alot in the cold north and northwest and the normal gear oil will freeze up. I go thru trannys not because of fluids, but mainly because of load weights, The F-550 can and does haul up to 9,000 lbs on the flatbed and the F-350 runs up to 6500 lbs on it's back. A lot of time it's chemical totes which slosh and believe it they can put extra stress on the drive train when the start moving all the liquid around. I do live on the road, I usually adverage about 215,000 miles a year. My F-350 pickup which I pull my Rv with still has it's original tranny an E4OD.
#1367
yeah,
i use castrol high mile gtx and a guart of slick 50 in my ranger. the oil gets changed about every 6000 miles. the tranny is oem 5spd. i just recently changed the atf in it,
i put amzoil atf in it. and the rear has amzoil 75/90 in it. i just changed over the tranny and the rear diff to amzoil. i guess they have a higher mileage between change intervals. the motor has castrol/slick 50. the air filther is a k&n reuseable all i do a couple times a year is clean it.
i work at a tranny shop, here in oregon. we have done full amzoil change overs. some people spend about $400.00 on fluids and diff oils. if they do alot of driving. in the long run i guess it would be worth it.
ford ranger
jack
ford ranger
jack
#1368
#1370
Originally Posted by OverEngineer
Ok, I'll bite. How do you post photographs?
#1373
Originally Posted by bdrummonds
you can insert an image from Photobucket or some other photo hosting site now, or when you have posted 26 times the permission will be granted and you will be able to upload photos to your posts from your computer. You can also create your gallery and add gallery images to your posts.
#1378
#1380
Originally Posted by sedrick38
I have a 1999 F250 Super Duty with a 5.4 V8, I have 200,300 miles on it. It seems to burn a lot of gas, is this normal?
